Page 80 of 99 FirstFirst ... 70787980818290 ... LastLast
  1. Posts : 1,944
    Windows 10 Home 64-bit
       #790
    Okay. I did that. It did open the desktop folder without error.
  2. Posts : 72,100
       #791
    Ok, good. Try copying and pasting the command below in an elevated command prompt one more time.
    findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt"
  3. Posts : 1,944
       #792
    I am still getting the same error.
  4. Posts : 13,576
    Jesse, what has told you you have corrupted files ?
    You are well aware of the updates that cause a false corrupt file reading, that were discussed earlier, corret ?
  5. Posts : 1,944
       #794
    The SFC commands has told me that I have a corrupt file. Follow the link, and that will direct you to the whole thing of what is going on. Windows Update: Service Registration Is Missing or Corrupt
  6. Posts : 72,100
       #795
    I must admit that I don't know why the command won't work for you when it has no problem finding either location by themselves.
  7. Posts : 1,944
       #796
    I don't know either. Is there another way I can see what files are affected and how to repair them?
  8. Posts : 72,100
       #797
    You can copy your CBS.log file from the %windir%\Logs\CBS folder to your desktop, then try the command below to see if it'll create a sfcdetails.txt file for you. :)
    findstr /c:"[SR]" "%userprofile%\Desktop\CBS.log" >"%userprofile%\Desktop\sfcdetails.txt"
  9. Posts : 1,944
       #798
    Okay. Well, every time I try to open the CBS Log, it says Access Denied.
  10. Posts : 72,100
       #799
    You will have to copy the CBS.log to your desktop first, then run the command I posted above.
