Open in New Process - With or Without Shift+Right Click Context Menu
    How to Use "Open in New Process" Context Menu Item With or Without Shift+Right Click
    This will show you how to be able to use the Open in New Process context menu item with or without Shift+Right Click on a folder or drive for all users in Windows 7 and Windows 8.
    You must be logged in as an administrator to be able to do this tutorial.
    EXAMPLE: "Open in new process" with or without Shift+Right Click in the Context Menu
    Open in New Process - With or Without Shift+Right Click Context Menu-shift-right-click.jpgOpen in New Process - With or Without Shift+Right Click Context Menu-right-click.jpgOpen in New Process - With or Without Shift+Right Click Context Menu-modified.jpg
    Here's How:
    1. Shift+Right Click "Open in new process" in the Context Menu
    A) Click/tap on the Download button below to download the file below, and go to step 3 below.
    Shift+Right-Click_Open_in_New_Process.reg
    2. Right Click "Open in new process" in the Context Menu
    4. Double click/tap on the downloaded .reg file to merge it.
    5. Click/tap on Run, Yes (UAC), Yes, and OK when prompted.
    6. If open, close and reopen Windows Explorer to see the change.
    7. When finished, you can delete the downloaded .reg file if you like.
  1. NoN
    Thanks for that right-click behavior .reg. Handy!
  2. Posts : 72,145
    You're welcome mate. :)
  3. NoN
    Yes indeed!
    As it had been said in "How to Add "Select all" to the Context Menu in Windows 7" tutorial already...i quit love right-click menu for my laziest purposes!
  4. Posts : 72,145
    LOL, anything that makes it easier to do.
  5. Posts : 5,105
    Windows 7 Professional 64-bit SP1
    I went for option 2 ... brilliant ! thank you Shawn :)
    Ciara ... X
  6. Posts : 72,145
    You're most welcome Ciara. :)
