Folder Template - Default
Page 1 of 9 123 ... LastLast
    How to Set a Default Folder Template for All Folders in Windows 7
    This will show you how to either set a folder template of your choice to be the default for all folders, or reset all folder templates back to default in all folders in Windows 7.
    The folder template for Library folders cannot be changed in Windows 7.
       Tip
    Automatic Folder Type Discovery is when Windows will automatically change the folder template of a folder to match the file type of the last file added or saved in the folder. For example, if your folder contains music files and you add a picture file, then Windows may change the folder template and view to the "Picture" template to match the new picture file.
    By setting a specific template (steps 2 to 6) to be the default, you will disable Automatic Folder Type Discovery. Afterwards, you will still be able to set folder views and templates how you like, but without Automatic Folder Type Discovery changing them for you.
    By restoring the default templates (step 1), you will enable Automatic Folder Type Discovery.
    EXAMPLE: General Items, Documents, Pictures, Music, and Video templates
    NOTE: These screenshots are with using the Details view. What you see in your window will also depend on what you have the View arrangement, Group by, Sort by, Stack by arrangement, or icon size set as.
    Here's How:
    1. To Restore Default Folder Templates for All Folders
    NOTE: This will also reset all folder views back to default as well.
    Restore_Default_Folder_Templates.bat
    Download
    B) Go to step 7.
    2. To Set General Items Folder Template as Default for All Folders
    All_Folders_Use_General_Items_Folder_Template.bat
    Download
    B) Go to step 7.
    3. To Set Documents Folder Template as Default for All Folders
    All_Folders_Use_Documents_Folder_Template.bat
    Download
    B) Go to step 7.
    4. To Set Pictures Folder Template as Default for All Folders
    All_Folders_Use_Pictures_Folder_Template.bat
    Download
    B) Go to step 7.
    5. To Set Music Folder Template as Default for All Folders
    All_Folders_Use_Music_Folder_Template.bat
    Download
    B) Go to step 7.
    6. To Set Videos Folder Template as Default for All Folders
    All_Folders_Use_Videos_Folder_Template.bat
    B) Go to step 7.
    7. Save the .bat file to your desktop.
    8. Close all running programs and opened windows, and run the downloaded .bat file.
    9. If prompted, click on Run.
    NOTE: If you like, you can stop getting the Run prompt by unblocking the downloaded .bat file.
    10. You will now notice your screen flicker as explorer is restarted to apply the registry changes.
    11. You can delete the downloaded .bat file if you like.
  1. Posts : 124
    Dual boot XP Pro and Seven/7127
    Sorry but, this folder template issue confuses me
    It seems that using one of the above folder templates will alter ALL of my folders throughout the whole computer. Is that true?
    I don't want that to happen.
    For example, I have folders for docs, folders for photos, folders for music files - I suppose we all have.
    Sometimes photos and images are displayed in a folder layout that is more suited to music files.
    At other times my music files are arranged in a folder that has headings for images. Grrhh. Specifying Folder Options has no effect - it never has worked, for me.
    I don't seem to be able to win with this one.
    The problem was with me in XP and is still haunting me in Win 7.
    Will using A Selection of the folder templates that I like resolve my problem and display photos in a picture folder, docs in a documents folder, and music files in a music folder. Or can I use but one folder template.
  2. Posts : 72,059
    Hello AnyKey,
    Using this tutorial will change and affect all folder templates. If you want to only change the template for one folder at a time, then you would want to use the tutorial below instead. See the related links as well for other options on this.
    Folder Template - Change
  3. Posts : 557
    Windows 7 x64 Ultimate SP1
    Brink I'm not sure if you have this, but if you want to add it to your tutorial, be my guest.
    You can prevent Windows from sniffing folder contents and automatically assigning the folder type template
    [HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\shell]
    "FolderType"="NotSpecified"
    Cheers.
  4. Posts : 72,059
    Hello Zardoc,
    Thank you for reminding me about this. I just didn't have the time to add it yet as a separate tutorial from the tutorial below, then forgot about it.
    Windows Explorer Folder View settings - Vista Forums
    It's on the list for tonight.
  5. Posts : 557
    Since you built most of this tutorial, I tought it might be respectfull to let you finish it off.
  6. Posts : 72,059
    Thank you sir. :)
  7. Posts : 557
    You are most welcome my friend!!
  8. Posts : 72,059
    Zardoc,
    No need to create a separate tutorial. Adding the TIP box at the top should work just as well. :)
  9. Posts : 124
    Cheers.
    Ah this sounds like what I want.
    I shall look forward to reading the tutorial.
    esp to know what Windows (7) will do if you tell it to stop "automatically assigning the folder type template".
    At the moment I simply cannot get Windows 7 to display docs in a folder of docs, photos in a folder of photos, and music in a folder of music.
