Notification Area - Add or Remove
    How to Add or Remove Notification Area from Taskbar in Windows 7 and Windows 8
    The notification area is a part of the taskbar that provides a temporary source for notifications and status. It can also be used to display icons for system and program features that are not on the desktop.
    The notification area (aka: system tray) is on the far right of the taskbar just to the left of the system clock. This includes the default Volume, Network, Power, Action Center, and Input Indicator (Windows 8) system icons in addition to all system tray icons added by installed programs.
    This tutorial will show you how to add or remove the notification area from the taskbar for all or specific users in Windows 7 and Windows 8.
    You must be logged in as an administrator to be able to do this tutorial.
    If you remove the notification area, then the taskbar displays only the Start button, pinned taskbar buttons, custom toolbars (if any), and the system clock.
    You will also no longer be able to set the Notification Area Icons and System Icons settings as well since the notifcation area is no longer there to display them and their balloon messages on.
    EXAMPLE: Notification Area on Taskbar Added and Removed
    OPTION ONE
    Using a REG File Download
    1. To Add Notification Area to All Users Taskbar
    A) Click on the Download button below to download the file below, and go to step 3 below.
    Add_Notification_Area.reg
    2. To Remove Notification Area from All Users Taskbar
    Remove_Notification_Area.reg
    Download
    3. Save the .reg file to your desktop.
    4. Double click/tap on the downloaded .reg file to merge it.
    5. Click/tap on Run, Yes (UAC), Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply.
    7. When finished, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, and Start Menu and Taskbar. (see screenshot below)
    3. In the right pane, double click/tap on Hide the notification area to edit it. (See screenshot above)
    4. To Add Notification Area to Taskbar
    A) Select (dot) either Not Configured or Disabled, and go to step 6 below. (see screenshot below step 6)
    5. To Remove Notification Area from Taskbar
    A) Select (dot) Enabled, and go to step 6 below. (see screenshot below step 6)
    6. Click/tap on OK. (see screenshot below)
    8. Log off and log on, or restart the computer to apply.
  1. Posts : 3,302
    Nice one Shaun not something i would use but im sure people who need the real estate on the taskbar will be glad of this
    Danny
  2. Posts : 72,052
    Thank you Danny. :)
  3. Posts : 2,298
    Good Tutorial , Easy to use and Informative , Good one Shaun
  4. Posts : 72,052
    Thank you Josh.
  5. Posts : 8,679
    Another great tutorial Brink! Keep at good work!
  6. Posts : 72,052
    Thank you Boshko.
  7. Posts : 7
    Win 7, 64 bit home Premium
    Just wanted to say...
    This is by far the best forum I have found for Win 7. So far, with your excellent instructions, I have cleared my NC of old programs I uninstalled, deleted my library and re-formatted my user folder.
    I am not an IT person at all, and was afraid to edit my registry, but with your help all operations have been successful!
    Many Thanks for helping me solve these issues. :)
  8. Posts : 72,052
    You're most welcome Dapa, and welcome to Seven Forums. I'm happy to hear that they were all able to help. :)
  9. Posts : 74
    Windows 7 Ultimate 64-bit SP1
    thanks
