Control Panel - Add or Remove "All Tasks" (God Mode)
    How to Add or Remove "All Tasks" (God Mode) from Control Panel in Windows
    This will show you how to add All Tasks (God Mode) to the Control Panel for all users in Vista, Windows 7, and Windows 8.
    EXAMPLE: "All Tasks" (God Mode) added to Control Panel
    NOTE: This is the Control Panel icons and category view.
    EXAMPLE: Control Panel "All Tasks" List
    NOTE: This will show you every task available in the Control Panel listed by category. Some of these are not normally displayed in the Control Panel.
    Here's How:
    1. To Remove "All Tasks" from Control Panel
    A) Click/tap on the Download button below to download the file below.
    Remove_All_Tasks_from_Control Panel.reg
    Download
    B) Go to step 3.
    2. To Add "All Tasks" to Control Panel
    Add_All_Tasks_to_Control Panel.reg
    3. Save the .reg file to the Desktop.
    4. Double click/tap on the downloaded .reg file to Merge it.
    5. Click/tap on Run, Yes, Yes (UAC-Windowws 7/8) or Continue (UAC-Vista), and OK when prompted.
    6. When finished, you can delete the .reg file if you like.
  1. Posts : 205
    Windows 7 Home Premium
    V Powerful .. Thanks Shawn !!!
  2. Posts : 72,058
    You're welcome nooruddin. :)
  3. Posts : 205
    not able to add to Ur rep ..cause it says I need to spread it around :) .. wait i Know another one who was helpful :)
  4. Posts : 1
    windows 8.1 64 bit
    not able to add to ur rep, as it says you cant nevertheless thanks very much.
