System Tools - Cascading Desktop Context Menu
    How to Add a "System Tools" Cascading Desktop Context Menu in Windows 7
    This will show you how to add or remove a cascading (expandable) System Tools menu to the desktop context menu for all users in Windows 7.
    This is the same folder and items as in the Start Menu - All Programs - Accessories - System Tools folder.
    You must be logged in as an administrator to be able to do this tutorial.
    EXAMPLE: System Tools Cascading Desktop Context Menu
    Here's How:
    1. Add "System Tools" Cascading Desktop Context Menu
    Add_System_Tools_to_Desktop_Context_Menu.reg
    B) Go to step 3.
    2. Remove "System Tools" Cascading Desktop Context Menu
    Remove_System_Tools_from_Desktop_Context_Menu.reg
    3. Click on Save, and save the .reg file to the desktop.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. When done, you can delete the downloaded .reg file if you like.
  1. Posts : 3,302
    Very handy Shawn its quite a hike to get to that option through the start menu by hand
    Danny
  2. Posts : 72,062
    I'm glad that you like it Danny. Thank you. :)
  3. Posts : 851
    Windows 8 Professional x64
    Nice one shawn
  4. Posts : 72,062
    Thank you sir. :)
