Gathering a Startup, Shutdown, Sleep, Hibernate, or Reboot Trace
Page 3 of 10 FirstFirst 12345 ... LastLast
  1. Posts : 2,528
       #20
    No, no defragmenting. Also, as long as you end up with an .ETL file (and potentially a .CAB file) in the output folder after that error on the screen, you are fine.
  2. Posts : 49
    Windows 7 Professional x64
       #21
    Boot trace Failure
    I was following your tutorial to start a boot trace with xbootmgr and i ran into a pit fall. xbootmgr did not even get to the stage of restarting my system to create the trace. Instead i got a pop up saying "Could not register for callback at next boot."
    I checked to see if a log file was created and on my root directory i found the xbootmgr log file
    [2012/03/17-21:53:39.716] The file 'C:\Windows\system32\cmd' is not a valid callback command.
    [2012/03/19-19:23:05.102] Detected Win7RTM physical (ReadyBoot) prefetcher; the SysMain service is auto-started.
    [2012/03/19-19:23:05.104] Registering for auto-run with a 120000 msec delay...
    [2012/03/19-19:23:05.104] Failed to open auto-run reg key with 0x00000002.
    [2012/03/19-19:23:05.104] Could not register for callback at next boot.
    Does anyone know what registery key that xbootmgr might have failed to open?
  3. Posts : 2,528
       #22
    Are you sure that you are running the cmd prompt to launch the command with full administrative credentials (aka, run as admin while logged on as an administrator)?
  4. Posts : 5
    Windows 7 Pro x64
       #23
    So I am assuming that once we do this, we need to reset the PagingExecutive value back to "0" correct?
  5. Posts : 2,528
       #24
    Yes, that would be recommended.
    Sent from my SGH-i917 using Board Express
  6. Posts : 661
    Windows 7 Home Premium SP1 64-bit
       #25
    Yet again, having followed the tutorial to the letter, I just end up with an error message at the end of the process (after the reboot and the 5' wait for the trace). Am I ever going to get this to work? Any ideas what is wrong this time? The error message is below. Thanks again for any help.
    Martin
  7. Posts : 2,528
       #26
    Assuming you are logged in with administrative credentials, that shouldn't happen. If you're logged in as a regular user, you should get a UAC prompt. If you've disabled UAC, the tool may not work (with the type of error you see).
  8. Posts : 661
       #27
    I'll try again with UAC active, Thanks!
    M
  9. Posts : 2,528
       #28
    Disabling UAC disables a bunch of things, not just UAC prompts .
  10. Posts : 661
       #29
    Ran the trace again with UAC active (in the default setting) - unfortunately I get exactly the same error message as before. Appreciate fruther ideas..
    Martin
