System Info - See Your System Specs
Page 1 of 16 12311 ... LastLast
    How to See Your System Specs with "System Info"
    System Info is free Seven Forums program that CyberZeus has kindly made for us. It let's you easily see all of your system information, and has an option to make filling out your system specs here at Seven Forums easier to do.
    Here's How:
    1. Click on either Download button below to download and save the SystemInfo.exe file to your desktop.
    (EXE file)
    Download
    (ZIP file)
    Download
    2. Run the SystemInfo.exe file.
    NOTE: This is a standalone .exe file that only runs and does not install anything on your computer. If you would like to stop getting the Run prompt, then unblocking the SystemInfo.exe file will stop it.
    3. After System Info loads, you will see a summary of your system's information.
    NOTE: There's a Edit System Specs link at the bottom right that will take you to your system specs here at Seven Forums.
    4. Do either step 5 or 6 below for how you would like to fill out your system specs at Seven Forums.
    5. To Automatically Fill Out your System Specs at Seven Forums
    NOTE: This step can only be done using Internet Explorer.
    A) In System Info, click on Options (menu bar), Settings, select (dot) Automatic Mode, and click on OK. (see screenshots below)
    System Info - See Your System Specs-system_info.jpgSystem Info - See Your System Specs-options_settings.jpg
    B) Click on the Edit System Spec link at the bottom right corner of System Info. (see left screenshot above)
    C) If you are not already, log in to Seven Forums in the new IE Seven Forums' Site window that just opened. (see screenshot below)
    D) Click on the Set info button at the top left corner to automatically enter the information from System Info into your system specs at Seven Forums, then click on the Save Changes button at the bottom to save them. (see screenshot below)
    6. To Manually Fill Out your System Specs at Seven Forums
    A) Clicking on each device icon will give you a pop-up with more detailed information about that device.
    System Info - See Your System Specs-cpu.jpgSystem Info - See Your System Specs-motherboard.jpg
    System Info - See Your System Specs-bios.jpgSystem Info - See Your System Specs-memory.jpg
    System Info - See Your System Specs-hard_disk.jpgSystem Info - See Your System Specs-logical_disk.jpg
    System Info - See Your System Specs-sound_card.jpgSystem Info - See Your System Specs-graphics.jpg
    System Info - See Your System Specs-network.jpgSystem Info - See Your System Specs-os.jpg
    B) In System Info, click on Options (menu bar), Settings, select (dot) Manual Mode, and click on OK. (see screenshots below)
    C) Click on the Edit System Spec link at the bottom right corner of System Info. (see left screenshot above)
    D) You can now use the information in System Info to fill out your system specs at Seven Forums by clicking on the System Info - See Your System Specs-copy_to_clipboard.jpg button to the right of a system spec in System Info to copy it to the clipboard, then right click in a system specs field at Seven Forums like below and click on Paste. When finished filling out your system specs, be sure to click on the Save Changes button at the bottom to save them.
  1. Posts : 17,322
    Win 10 Pro x64
    Nice explanation Shawn, I noticed on the tool itself it will take you right to your system specs if you click on edit system specs at the bottom.
    Handy tool CyberZeus.
  2. Posts : 25,847
    Thank you Mr. Brink. Nice little tool.
  3. Posts : 313
    Windows 7 Ultimate x64 SP1 clean install
    Perfect explanation Brink!
    I could never do it better!
  4. Posts : 14,606
    Edited system spec using the tool, thanks cyberzeus and brink.
  5. Posts : 8,679
    Great !
  6. Posts : 313
    You're welcome!
  7. Posts : 2,393
    Microsoft Windows 7 Ultimate: x64 (SP1)
    Nice design I have to say.
    Best Regards,
    FredeGail
  8. Posts : 1,808
    Windows 7 64b Ultimate
    Great tool, great explanation! Well done to both!
  9. Posts : 12,177
    Another great tut, thanks Brink.
    Great app, thanks CyberZeus for taking the time to make it.
