User Folders - Restore Default Location
Page 16 of 31 FirstFirst ... 6141516171826 ... LastLast
  1. Posts : 1
    Many thanks!
  2. Posts : 72,072
       #151
    You're most welcome Lambda, and welcome to Seven Forums. :)
  3. Posts : 1
    windows 7 64bit
       #152
    I just picked up Windows 7, and I initially tried to move “downloads” and “my documents” to another partition. Well, needless to say, I didn’t really pay attention or understand what was going on, and now in my user folder (by user folder I don’t mean C:/Users/Bryan but the Bryan folder you can access via the start menu) I have 2 download folders and 0 my documents folders. If I check C:/Users/Bryan there’s only one download folder.
    Now, if I try to delete one of the download folders from Bryan they both go away, in addition to the copy that is on my other partition (G:/Downloads).
    I assume I need to do option two, but before I start, let me clarify a few things. Should I delete all the download folders before I start option two or leave them, do option two, and then delete them afterward? Please clarify!
    I know this isn’t a huge deal but I like things a certain way and Windows 7 is turning out to be a very strange/buggy OS. I understand the library thing, but why is C:/Users/Bryan different from the Bryan folder? Very strange indeed!
    Thanks in advance!
  4. Posts : 72,072
       #153
    Hello Propama, and welcome to Seven Forums.
    I would first backup anything that you do not want to lose in those folders, delete them, and then see if using OPTION TWO on the affected user folders may be able to help. :)
  5. Posts : 2
    Win 8 64 bit / WinXp Dual boot
       #154
    Perhaps in the wrong Forum, but anyway will option 2 work with Windows 8? I've put My Documents into drive F: and now the Properties/ Location Tab has gone, so cannot move back to C:\Users............
    Roger
  6. Posts : 72,072
       #155
    Hello Roger, and welcome to Seven Forums.
    Yes, this tutorial will work in Windows 8 as well.
    If you are just wanting to save HDD space, then you might consider this below to be able to access the files from your libraries with the files actually located where you like instead. This way you will not have to worry about any potential issues that come with moving user folder locations.
    Hope this helps, :)
  7. Posts : 2
       #156
    Thanks for the informative answer Shawn.
    I will use option 2 to get things straight. The alternative you suggest looks good, will certainly give that a go.
    Thanks for your help
    Roger
  8. Posts : 72,072
       #157
    You're most welcome Roger. I hope it goes smoothly for you. :)
  9. Posts : 3
    Hope you can help me. In trying to restore My Documents folder I messed up and somehow created a linked folder that I can not access, see the screenshot below. Can you offer some suggestions to correct?
    Thanks,
    Arron
  10. Posts : 72,072
       #159
    Hello Arron, and welcome to Seven Forums.
    What process did you use to try and restore it with? It looks like you may have used a mklink command??
    Does it grant you access after you click on Continue?
