Take Ownership Shortcut
Page 45 of 45 FirstFirst ... 35434445
  1. Posts : 26
    Windows 7 Professional x64
       #440
    I didn't have it but I downloaded from tenforums and it worked. Thanks for that.
    The problem with the context menu shown in my previous post still persists though.
    Addendum:
    I turned off Test Mode and rebooted. My assumption was correct. Even in normal mode, "Run as administrator" does not show up when right-clicking the Command Prompt shortcut, or any shortcut.
  2. Posts : 72,061
       #441
    I'm not sure why the menu item is gone while using Test Mode.
  3. Posts : 26
       #442
    Whoops! Can't edit/delete the addendum now.
    As it says, problem still occurs in normal mode.
  4. Posts : 72,061
       #443
    Odd. You can see if this below may restore "Run as administrator".
    Run as Administrator - Add or Remove from Context Menu in Windows 7
  5. Posts : 26
       #444
    It was worth a try but unfortunately still no dice. I even tried removing it and running it again.
    - - - Updated - - -
    The culprit was Zip Genius.
    Won't be installing that again.
  6. Posts : 72,061
       #445
    - - - Updated - - -
    Glad you found the cause, and now have it sorted.
