Take Ownership Shortcut
Page 13 of 45 FirstFirst ... 3111213141523 ... LastLast
  1. Posts : 72,058
       #120
    Chiumiento said:
    Can I use this to take owner ship of the whole drive C if I want to?
    Hello Chiumiento,
    WARNING, DO NOT TAKE OWNERSHIP of the C: drive!!
    Doing so will mess up Windows 7 severely, and you will most likely end up having to reinstall Windows 7 to fix it.
  2. Posts : 237
    Brink said:
    Hello Chiumiento,
    I already have taking owner ship. I will go and change it right now. Hey do you think I could ask you a huge favor?
  3. Posts : 72,058
       #122
    Sure, I'll see what I may be able to do.
  4. Posts : 237
    I put the ownership all back to normal.
  5. Posts : 126
    windows 7 pro 64 bit
       #124
    Is this dangerous at all? I did this already but have since reinstalled 7 because the system was so screwed up. Everyone was telling me not to mess with permissions. Could this have caused any of that or can i still use it?
  6. Posts : 72,058
       #125
    Hello Dazco,
    It could be if abused. You would want to be carefull of what you took ownership of. For example, you would not want to take ownership of the entire C: drive (Windows 7 drive). Also, if you take ownership of a file and granted your account permission to access it, then anything running while you are logged into your account will also be able to access it as well.
  7. Posts : 2
    windows 7 professional 32 bit
       #126
    THANKS A MILLION
    I can't thank you enough! I've been having trouble with this issue ever since I upgraded to Windows 7, and this shortcut fixed it in a jiffy.
  8. Posts : 7
    Thank you very much! This saved a lot of time for me!
    One file allows you to take ownership and the other removes the registry. :)
  9. Posts : 156
    Windows 7, Windows 10 Pro
       #128
    Thanks for this great utility. how do you change the ownership back to normal or default?
  10. Posts : 72,058
       #129
    Hello Sammy,
    Unfortunately, you would have to manually change the ownership back to whatever was set as the owner previously. If you forgot who or what the owner was previously, you can always create a new thread to ask what it was for that file. :)
    Take Ownership of file - Vista Forums
    TrustedInstaller - Restore as Owner - Vista Forums
