Take Ownership Shortcut
Page 24 of 45 FirstFirst ... 14222324252634 ... LastLast
  1. Posts : 124
    Windows 7 Ultimate x64, Windows 8.1 Pro x64 (on laptop)
       #230
    very handy for editing the host file, thanks !
  2. Posts : 43
    Windows 7 Pro x64 (Upgrade, Clean Install)
       #231
    Thank you, Brink! I'll head over there and read.
    BTW, it looks like I have re-register to post in the 8 Forums? It won't accept my current ID/password.
    Brink said:
    Hello spddemun,
    We have a separate tutorial for Windows 8 below, but Yes, it works in Windows 8 as well. :)
    Take Ownership - Add to Context Menu in Windows 8
  3. Posts : 72,165
       #232
    spddemun,
    Yeah, since it's a separate site it will require a separate registration as well.
    Register at Windows 8 Forums
  4. Posts : 91
    Ultimate x86 & x64
       #233
    Works for x64 systems too? Well i just added the .reg then system32 @addOwnership, go to security tab, can't change any permissions, can't add myself, still says access refused just like before i clic on addOwnership... What do i do
  5. Posts : 72,165
       #234
    Hello goja,
    Yep, the "Take Ownership" context menu works in both 32-bit and 64-bit Windows 7.
    Using the link in the yellow Tip box at the bottom of the tutorial, double check to make sure you are the "owner", and then try setting permissions for it.
    What are you trying to take ownership of?
  6. Posts : 91
    Ultimate x86 & x64
       #235
    As i just told you, i've done that, i'm trying it on system32 (as i wanted to overwrite a file in it) and when i add my account and set full control it says i can't, access denied.
    Now i'm quite worried about all that so i'll add a question : After we took ownership, can we remove it? I'm not talking about account authorizisations.
  7. Posts : 72,165
       #236
    Goja,
    I suggested for you to double check that you actually had ownership since you couldn't set permissions. That's usually the cause.
    You do not want to take ownership of the System32 folder, so it's a good thing it didn't let you.
    Instead, only take ownership and set permissions of the specific file instead.
  8. Posts : 91
    Ultimate x86 & x64
       #237
    Double check I had permission, how do I do that? Wanna know. And what shut my other question?
  9. Posts : 72,165
       #238
    For single files, it's not hard to restore the default owner. If you take ownership of the System 32 folder, then forget it. There's no going back unless you created a restore point before doing it.
    It's highly recommended to not do this with the System32 folder.
    You could use OPTION THREE in the tutorial below to manually take ownership and set permissions of the file.
    Take Ownership of file
  10. Posts : 91
    Ultimate x86 & x64
       #239
    How dko.i.know if i took ownership or not?
