#280
One more annoying thing with Windows 7. If you launch a program as an administrator, you, the user who launched that program, may not have full access rights to files it creates even if you have administrator rights.
One example, the game Kerbal Space Program creates a log file. In some cases Windows will block the game from being able to write to its own files and folders - even when it's not installed in Program Files. Launch it as an administrator and the user with admin rights is blocked from having write access to the game's log and save files.
But make a copy of them and delete the old file and you have full access until the game is run again as an administrator, upon which Windows 7 will put a write access block on the files. If the game is run again not as an administrator, then it's blocked from some of its own files unless the user makes copies and deletes the originals.
That's not security, that's just being pointlessly annoying. A secure file is one that only the user that created it can access when logged in. If anyone else can have full access to a file simply by making a copy, then there is no point at all to doing a half-measure access block. It's just like having a locked vault door with the combination code posted next to it.
Is there a way to turn that "feature" off?
