"Always use selected program" - Always Checked or Unchecked
Page 1 of 3 123 LastLast
    How to Have "Always use selected program" Always Checked or Unchecked in "Open with"
    This will show you how to have the Always use the selected program to open this kind of file check box to always be checked or unchecked by default in the Open with dialog box in Windows 7 and Vista.
    You must be logged in as an administrator to be able to do this tutorial.
    EXAMPLE: "Open with" with "Always use selected program" Always Unchecked by Default
    OPTION ONE
    To Have "Always use selected program" Check Box Always Unchecked by Default
    1. Go to the site below, or click on the Download button below, to download the MyOpenAs.zip file.
    2. Click on Save, save the zip file to your desktop, and extract all (drag and drop) contents of the zip to your desktop. (see screenshot below)
    "Always use selected program" - Always Checked or Unchecked-extracted-contents.jpg
    3. Do either step 4 or 5 below depending on if you have 32-bit (x86) or 64-bit(x64) Windows 7 or Vista installed.
    4. If you have 32-bit (x86) Windows 7 or Vista Installed
    A) Open the extracted x86 folder from step 2, and copy and paste the MyOpenAs.dll file into the C:\Windows\System32 folder.
    B) If prompted, click on Continue and Yes to approve pasting it into the C:\Windows\System32 folder.
    C) Go to step 6.
    5. If you have 64-bit (x64) Windows 7 or Vista Installed
    A) Open the extracted x64 folder from step 2, and copy and paste the MyOpenAs.dll file into the C:\Windows\System32 folder.
    C) Go to step 6.
    6. Right click on the extracted MyOpenAs.reg file from step 2, and click on Merge.
    7. If prompted, click on Run, Yes (UAC-Windows 7) or Continue (UAC-Vista), Yes, and OK.
    8. Go to the site below, and follow the instructions there.
    OPTION TWO
    To Have "Always use selected program" Check Box Always Checked by Default
    3. Right click on the extracted MyOpenAs_RestoreDefaults.reg file from step 2, and click on Merge.
    4. If prompted, click on Run, Yes (UAC-Windows 7) or Continue (UAC-Vista), Yes, and OK.
    5. Open the C:\Windows\System32 folder in Windows Explorer, and delete the MyOpenAs.dll file. (see screenshot below)
    6. If prompted by UAC, then click on Yes (Windows 7) or Continue (Vista) to approve deleting it.
    7. Go to the site below, and follow the instructions there.
  1. Posts : 28
    Windows 7 Home Premium 64 bit
    This should be the default factory setting. I find unbelievable that Microsoft went to such extent to make their OS secure, castrating users of their basic rights, but left that checkmark so that inexperienced users can easily install spyware and rogue programs.
  2. Posts : 72,061
    Hello Nondisposable,
    I agree that it would be best to have it always unchecked to be safe. I suppose that Microsoft felt that if you went to the trouble to change the "Open with" program, then you would most likely want to have it as the new default program as well, so they were just trying to make it more convenient to do so. To bad, it could backfire on the inexperienced though.
  3. Posts : 582
    So far I have managed to Extract but how do I find the system32 folder to do the "copy/paste" step?
  4. Posts : 72,061
    Hello Grits,
    You would need to open Windows Explorer, manually navigate to the C:\Windows\System32 folder, and open the System32 folder. :)
  5. Posts : 582
    Whew, stumbled a bit but believe I got it done, now do I save or delete everything except the two that got copied/pasted & merged?
    Thanks.
  6. Posts : 72,061
    You're most welcome. Nope that's it. :)
  7. Posts : 1
    Windows 7 X64
    File not found anyone has it please share
  8. Posts : 72,061
    Hello Rachini, and welcome to Seven Forums.
    Looks like their server is down for now. I've added a direct download link for the file to use. :)
  9. Posts : 2
    Doesn't Work For Unknown Filetypes
    This does not work if opening an unknown filetype (aka a file for which there isn't already a program associated); in that case, the checkbox is still checked by default. This only seems to work if you right-click a file that's *already* associated with a program, and Open With->Choose default program.
    It appears that the dll posted is part 1 of the tutorial here: http://blogs.msmvps.com/dmartin/blog...ed-by-default/
    ...But omits part 3, for a complete solution: http://blogs.msmvps.com/dmartin/blog...ault-part-iii/
