Screen Saver - Turn On or Off
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 72,062
    I'm not sure if you can do this on demand with a screen saver, but you could use a Lock computer shortcut or Windows Key + L to instantly lock the computer to the log on screen.
  2. Posts : 353
    Win 7 Ultimate x64
    Why does my screen saver keep reverting to OFF On it's own. Really starting to bug me now.
  3. Posts : 72,062
       #12
    Hello Chris,
    Try saving your theme to see if that may help.
  4. Posts : 353
    Win 7 Ultimate x64
    My theme is already saved
  5. Posts : 72,062
       #14
    Chris,
    Is it a 3rd party screen saver that you are using?
    If not, then you might see if doing a sfc /scannow may help, and if not, then a repair install.
  6. Posts : 353
    Win 7 Ultimate x64
       #15
    Brink said:
    Chris,
    No, it's just "Ribbons". Doing the scan now.......
  7. Posts : 353
    Win 7 Ultimate x64
       #16
    scan complete, I got some message about a repair needing a reboot, just curious though, on a side note, is it possible that "sfc /scannow" could've reverted my custom icon set (MrGrim's) I had installed? It would appear now that any new folder's I create are the original Win7 icons now.
  8. Posts : 72,062
       #17
    Yes, a sfc /scannow command will restore the system files back to their original unmodified state, and replace any corrupted ones if able. Sometimes a restart is needed afterwards to finish fixing corrupted or modified system files that are in use. That's all.
  9. Posts : 353
    Win 7 Ultimate x64
       #18
    Ok now what, I've reinstalled the icon set by Mr. GriM, reboot, and nothing, icons are still messed up.
  10. Posts : 72,062
       #19
    Looks like a repair install will be needed then.
