Darik's Boot and Nuke - Use to Secure Wipe a Hard Drive
  1. Posts : 84
    windows 7 ultimate x 64bit
    ok just tried this but it came up with errors and push the power button to switch off the pc
  2. Posts : 72,058
    What errors did you get?
    You will not be able to do this on a Windows hard drive that you are currently running since Windows is in use.
    What were you wanting to do? Perhaps there may be another or easier way to do it.
  3. Posts : 84
       #12
    i have 2 hdds in my pc one has been cleaned with diskpart and i want to clean my main hdd that has w7 on it then re install from fresh as i might be selling it so i want all sensitive info erased
  4. Posts : 72,058
    Did you boot from the created Darik's Boot and Nuke DVD to do this with?
  5. Posts : 84
       #14
    i cant remember the errors
    yes i followed the tutorial
  6. Posts : 72,058
       #15
    Ok, but we still need to know what errors you got when you tried to be able to try and figure out what may have happened.
    If you like, you could boot to a command prompt at boot, and just run a "Clean All" command on the Windows hard drive to do a 1 pass secure delete of it instead. That will pretty much make any data that was on it unrecoverable as well. :)
  7. Posts : 84
       #16
    thanks i was looking into that , i will give it a go
  8. Posts : 72,058
       #17
    You're welcome. Please let us know how it went. :)
  9. Posts : 126
    Windows 7 Professional x64
       #18
    Brink... I have a Dell computer that I want to give to a needy family for their son to finish school with. I want to remove my personal info before I do. Can I use DBAN to do this and still be able to reinstall Windows 7? Is this the easiest way to accomplish what I need it to do?
  10. Posts : 72,058
       #19
    Hello McLeod,
    Yes, you could use this to secure erase everything on the computer to be basically unrecoverable, then reinstall Windows 7 on it again afterwards.
    You could also use the "clean all" command at boot to do a 1 pass secure erase the HDD.
    Be sure that you have Windows 7 installation media, and the product key number from the Dell first to be able to reinstall later of course.
    Clean Reinstall - Factory OEM Windows 7
    Hope this helps. :)
