Hibernate Shortcut - Create
Page 1 of 3 123 LastLast
    How to Create a Hibernate Shortcut in Windows
    This tutorial will show you how to create a shortcut for Hibernation on the desktop. This can then be moved anywhere you like.
       Warning
    You will need to enable hibernate for this hibernate shortcut to work. Otherwise it will put your computer to sleep instead.
    Step 1: Right click on the desktop and select New -> Shortcut
    Step 2: Type this into the location field:
    C:\Windows\System32\rundll32.exe powrprof.dll,SetSuspendState 0,1,0
    Step 3: Name it whatever you would like:
    You now have your Hibernation shortcut!
    Step 4 (optional): Change the icon to something meaningful. Right click on the shortcut, and select Properties. In the Shortcut tab, choose "Change Icon". You can use the default icons in there, or choose from the power icons by clicking browse, and typing this:
    %SystemRoot%\System32\powrprof.dll
    Step 5: Enable hibernate.
    All done!
    ~Lordbob
  1. Posts : 39
    dual: windows 7 Ultimate x64 7600 and XP SP3
    Lordbob75. thanks for the guide. would you kindly help me to create two shortcurts to toggle between power schemes 'optimized' and ´performance´? that will help me to easily activate / deactivate the asus cool´n´quite feature inside windows 7. thanks m8
  2. Posts : 72,062
    Hello Tranqueirex, and welcome to Seven Forums.
    This may be what you are wanting. :)
    Power Plan - Create Shortcut to Change Power Plan
  3. Posts : 39
    Woha Brink! thanks to pinpoint that! it's EXACTLY what I'm looking for! :)
    nice forum I found it!
  4. Posts : 72,062
    You're most welcome Tranqueirex. :)
  5. Posts : 12
    Windows 7 Home Premium 64bit (desktop PC) and 32bit (old tablet PC)
    User Account Control pops up
    I followed the instructions to create a hibernate shortcut in Windows 7. When I use it, a window from User Account Control pops up asking "Do you want to allow the following program to make changes to this computer?" I would rather not disable UAC - is there another way to avoid being prompted?
    Teffy
    P.S. Thanks for an awesome site!
  6. Posts : 6,885
    I do not know of a way, but clicking Yes isn't a bad problem at least.
    ~Lordbob
  7. Posts : 5,056
    ~Lordbob
  8. Posts : 6,885
    Bill2 said:
    ~Lordbob
    Well there you go. Thanks for the link.
    ~Lordbob
  9. Posts : 6,305
    I've just spent 15 minutes putting together a pack to create a tutorial only to see this live post just as I'm about to start work on it. Nice find...Searches work wonders these days ops:
