Post Template: Create at Seven Forums
Page 1 of 3 123 LastLast
    Britton30
    Do you often find yourself typing the same thing in different threads? Use this tutorial to create and save several posts that can be used over and over.
    The post template system is only available to usergroups Guru and above.
    Creating a Template
    Step 1.
    Click on User CP at the top of a forum page, go to the bottom left of the CP page to Post Templates and click Manage Post Templates to get started.
    User CP may be located in a different place depending on the skin/theme you're using, this is Seven Blue.
    Post Template: Create at Seven Forums-1open-template-window.jpg
    Step 2
    In Add Category type in a name for the type(s) of posts these will be. In this example I have used Test but name it anything appropriate to the post(s). Click Create Template.
    Post Template: Create at Seven Forums-2add-cat.jpg
    Step 3
    The next window looks like a normal advanced posting window. At the top left there is a drop down menu where all categories you have created will be listed, select the one you need. I have other ones stored and we'll use Test created earlier.
    Add a title for this template to identify it for later use. You can now create the template here just as you would to make a normal post. Links, images, or smilies can be added.
    To add an image to your template you will have to use the [img] tags with a link to the image. The image can be from, say, Photo Bucket or from your album on the forum
    It is useful to add more info than you may need and then edit it after inserting your post in a thread. I have one for Add Specs where I can add the OP's name if I wish.
    Click Save changes and you're done!
    Post Template: Create at Seven Forums-4type-template.jpg
    Adding your template to a post
    Step 1
    In the thread you want to place a template you've created you must have the advanced reply window to see your templates. Click on the button or in the quick reply window on the Go Advanced button.
    Post Template: Create at Seven Forums-7go-advanced.jpg
    Step 2
    When the advanced reply window is open, there is a Post Template menu in the upper right. Click the arrow and all of your categories and template titles you have created will be listed here. Click the Title you want and it will be added to the text box for you. You can edit it as needed at this time.
    Post Template: Create at Seven Forums-8post-template-thread.jpg
    Editing a saved template
    Step 1
    As when starting to create a template, go to User CP/Manage Post Templates. In the window that opens there will now be listed the categories and titles you have added. Click where shown below, Manage Template next to the title you need to edit.
    Post Template: Create at Seven Forums-5edit-templates.jpg
    Step 2
    The template will open as you created it originally and you may make any changes needed here. Click Save Changes after editing.
    Post Template: Create at Seven Forums-6editable-template.jpg
    That's it you're done!
    Thanks to Brink for help with the editing parts.
    And to z3r010 for adding this useful feature.
  1. Posts : 1,870
    MS Windows 7 Professional 64-bit SP1
    Great Tutorial!! Wish you had done this the other week when I was trying to figure it out!!
    Thank you very much
  2. Posts : 15,026
    Windows 10 Home 64Bit
    Now I get it.
    Thanks for this Gary
  3. Posts : 3,302
    Well done Gary, very usefull
  4. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Thanks everyone, hope you find it useful.
  5. Posts : 14,606
    good tutorial, think of all those colorful templates that will be created
    save the first post as a template britton
  6. Posts : 178
    Windows 7 Home Premium Service Pack 1 32-bit Build 7601
    I followed your tutorial, when I click on User CP, I don't see Create Template or Manage Template on the left pane.
  7. Posts : 51,484
    Windows 11 Workstation x64
    The Post template facility is for Guru group and above only.
      My Computers
  8. Arc
    Nice job Gary :)
  9. Posts : 24,479
    Thanks for the edit.
    Thanks the bro peas.
