#110
Ah, I see. I'm happy to hear that you got it sorted though.
Hello, I am trying to delete disk 0. I cannot delete disk 0 because it set as a "system" disk. How can i remove this title from the disk in order to remove it. Thanks in advance for all your help. I sure hope someone still responds to this thread.
Hello,
Yes, we are still active. :)
Try booting into a command prompt, and deleting the volume using Diskpart.
Boot to your Windows DVD or repair disc; if you don't have either, create one: System Repair Disc - Create
Select "repair my computer", and open a command prompt. Enter the following commands:Make note of the number of the 150GB drive, and substitute that number for "n" in the commands below.Code:diskpart list diskThat should do the trick.Code:select disk n clean exit exit
"Clean is not allowed on the disk containing the current boot, system, pagefile, crashdump or hibernation value."
WAT DO
thanks
Hello Holtlol, and welcome to Seven Forums.
It sounds like you may have tried to Clean "Disk 1" instead of "Disk 0" by mistake. Double check to make sure that you have the correct disk # selected compared to it's size.
Following Brink's advice check that you are attempting to clean Disk 0. If no success then the following is likely to be the situation:
Disk 0 is still "System" meaning it contains boot files. The OS on C: is being booted through System on Disk 0 and hence the message you receive when trying to delete it.
Then
(1) make disk 1 Active.
(2) Disconnect the sata cable from disk 0 and connect it to disk 1, leaving the original disk 0 (the dynamic disk) disconnected.
(3) Run Startup repair 3 times.
"Disk 1, C:", now should then be (System, active, Boot...) and booting up by itself.
(4) Connect the old disk 0 by the sata disk 1 cable.
Then you can perform the operations on the "old Disk 0" now seen as Disk 1. I am guessing you want to make it a Basic disk again instead of dynamic.
Before sata cable changes make sure your PC is powered down.
You can always create a separate System Reserved partition on C: later if you want. In fact many people prefer not to have it.
If the issue has been resolved - feedback would be useful.
can i delete an empty extended partition using disk management? i only have 1 hard disk, and i keep getting an error.
Hello man, and welcome to Seven Forums.
Please post a screenshot of your Disk Management showing your drive layout. We will be happy to take a look at it to see if that may be possible for you. :)
I today noticed that there is a partition on my hardrive, i have tried to remove the partition using both of the above methods with no luck. when i try through the command prompt it shows an error message.
im stuck for ideas on what to try
