Partition or Volume - Delete
Page 14 of 17 FirstFirst ... 41213141516 ... LastLast
  1. Posts : 72,063
       #130
    lizziequirke said:
    Shawn,
    i cant start a system repair as when i turn my computer on it loads the toshiba screen then the error message shows and i cannot do anything else.
    What happens when you start tapping F8 as soon as you turn on or restart the computer?
    Do you have your retail Windows 7 installation disk or system repair disc in the DVD drive when you restart the computer?
  2. Posts : 21,004
       #131
    Thanks Shawn had been battling this little blighter for a couple of hours - then woke up to myself
  3. Posts : 72,063
       #132
    LOL, I hear you John. :)
  4. Posts : 3
    Help deleting the volume
    1st what i did is i tried to make a new local disk by shrinking local disk C, then comes a volume, i tried to format it, and it said do u wanna back it up, and i said no, and then it said file not specified,
  5. Posts : 72,063
       #134
    Hello TheGuy, and welcome to Seven Forums.
    The real problem is that you converted your OS disk to Dynamic. This will render Windows unbootable now. You can use the free EaseUS Partition Manager Home Edition to convert your Disk 0 back to Basic. The guide at the link below can help show you how to with this program.
    Convert dynamic disks to basic in Windows XP/2000/2003/2008/Vista/Windows 7/Windows 8 without data loss.
    Afterwards, see if this tutorial below can help you convert the unallocated 39.06 space to be a logical partition without converting the disk to Dynamic. The program above may work nicely to do so as well.
    Partition / Extended : Logical Drives
  6. Posts : 3
    Shawn i only see DIsk 1 (dynamic disk) theres no disk 0 so should i convert disk 1 to a basic disk????
    Also theres a thing that says unformatted *: and when i clicked on it the only option is to copy dynamic volume
    Attached Thumbnails Attached Thumbnails Partition or Volume - Delete-capture.jpg
  7. Posts : 72,063
       #136
    Yeah, it was only a reference from your first screenshot. :)
    You should see Convert to basic disk when you select and right click on the actual smaller Disk 1 Dynamic MBR section at the bottom left, or select C: (disk 1) at the bottom and click on Disk (menu bar). If not, could you post a screenshot of the options you have instead?
  8. Posts : 3
    Thx Shawn ive got my unlocated space back :)
  9. Posts : 72,063
       #138
    That's great news. You're most welcome. :)
  10. Posts : 2
    62 bit windows 7 home premium
       #139
    need help
    hey guys i need help
    i tried the first way and it says i cant delete it
    so i tried the second way and i typed in delete volume and says cannot delete
    so i tried the overdrive mode and says cannot delete in the current boot, system, pagefile crashdump or hibernation volume.
    please help
