Partition or Volume - Delete
Page 15 of 17 FirstFirst ... 51314151617 LastLast
  1. Posts : 12,012
       #140
    MattJKeogh said:
    hey guys i need help
    i tried the first way and it says i cant delete it
    so i tried the second way and i typed in delete volume and says cannot delete
    so i tried the overdrive mode and says cannot delete in the current boot, system, pagefile crashdump or hibernation volume.
    please help
    Matt:
    Post a screenshot of your Windows Disk Management so we can visualize what you are talking about.
    Might be best to do that in a fresh thread.
    What partition are you trying to delete?
  2. Posts : 10
    Windows 7 pro 64 bit
       #141
    Hi all I followed the DISKPART steps and it said - Successfully deleted the volume. after exiting and going back to Disk Management it still tells me that it is a Healthy (Primary Partition) with a RAW File System. I have refreshed Disk Management and closed and opened it again. Did I mention that it is a USB that I am trying to re create. I started with a successful DISKPART (clean all) that has also not removed the MBR by the looks of things. Any help or advise would be greatly appreciated please.
    Mike Walter
    Attached Thumbnails Attached Thumbnails Partition or Volume - Delete-diskpart.jpg
  3. Posts : 72,052
       #142
    Hello Mike, and welcome to Seven Forums.
    You could run the "Clean" command on the USB flash drive to wipe it out and make it "unallocated space".
    Afterwards, you should be able to just format the USB as usual. :)
  4. Posts : 10
       #143
    Hi Brink
    Thank you and thanks for replying I did do a clean all using DISKPART 1st and it said it was successful even though the MBR seems to still be there.
    Mike
  5. Posts : 10
       #144
    I have also done a disk wipe and partition re create using Mini Tool Partition Wizard now and still there seems to be no change, it still shows as RAW and I cannot format it.
  6. Posts : 72,052
       #145
    See if you may be able to "create a new primary partition" on it.
    Partition or Volume - Create New
  7. Posts : 10
       #146
    Disk Manager wont allow me to the options are all grayed out, if I try with Mini Tool it tells me apply all changes successfully but it still shows as unalocated in Mini Tool and as Healthy Primary RAW in Disk Management.
  8. Posts : 10
       #147
    And if I try and create using DISKPART I get the following error:
    Disk 1 is now the selected disk.
    DISKPART> CREATE PARTITION PRIMARY
    No usable free extent could be found. It may be that there is insufficient
    free space to create a partition at the specified size and offset. Specify
    different size and offset values or don't specify either to create the
    maximum sized partition. It may be that the disk is partitioned using the MBR di
    sk
    partitioning format and the disk contains either 4 primary partitions, (no
    more partitions may be created), or 3 primary partitions and one extended
    partition, (only logical drives may be created).
    DISKPART>
  9. Posts : 10
       #148
    It seem it has a bad Track 0 I tried an unconditional format and this is the response I received :
    C:\Users\216001>FORMAT F: /U
    Insert new disk for drive F:
    and press ENTER when ready...
    The type of the file system is RAW.
    The new file system is FAT32.
    Verifying 7651M
    Invalid media or Track 0 bad - disk unusable.
  10. Posts : 72,052
       #149
    Does the USB flash drive happen to have a write protect tab feature on it? If so, then you will need to turn it off first.
    In addition, you might see if you may be able to format the USB flash drive after using the free Active KillDisk on it.
