Partition or Volume - Delete
Page 5 of 17 FirstFirst ... 3456715 ... LastLast
  1. Posts : 3
    Hello Screen Shoot Attached
    Please see the screen shoot and tell me the solution
    Attached Thumbnails Attached Thumbnails Partition or Volume - Delete-partition.png
  2. Posts : 13,354
    Windows 7 Professional x64
       #41
    That free space is on an extended partition. It will not let you extend C into that space, unless you first convert the extended partition to a Primary one.
    Use Partition Wizard to assist you in this process.
  3. Posts : 3
    thanks
    wohoo thanks alot i have done it. I did it set partition as primary from partition wizard and then delete it from disk management and then extent it thanks aloooot
  4. Posts : 13,354
       #43
    Great, glad it worked. :)
    Let us know if you need anything else.
  5. Posts : 6
    I can't modify he partition labelled "unallocated" - all options but "Create" and the four at the bottom of the right-click menu are greyed out.
    What should I do?
  6. Posts : 13,354
       #45
    corona79 said:
    How can I determine if a partition is extended?
    Welcome
    Post a screenshot of your Disk Management window and one of us will take a look.
    A Preferred Method of Uploading/Posting Screen Shots
    An Extended partition is denoted by a dark green bar at the top.
  7. Posts : 6
    I just edited - please see previous post again.
  8. Posts : 13,354
       #47
    That is a Logical drive, that's all I can tell from that snip. Could you please post a screenshot of the full Disk Management window?
    Type diskmgmt.msc into the start menu and press enter.
  9. Posts : 6
  10. Posts : 13,354
       #49
    Try right-clicking on the unallocated space and selecting "Delete". Then create a new partition in that space.
    You may also try right-clicking in the dark green space indicated by the red arrows.
