Partition or Volume - Create New
Page 45 of 48 FirstFirst ... 354344454647 ... LastLast
  1. Posts : 14
    I just clean installed Win7 on a brand new 500GB hard drive. My intention was to create a 100GB C drive for the OS and the rest as D for data storage. Now I know I should have done so during the installation. After I finished all the Windows updates and program downloads, Disk Management only allowed ~230GB for a new partition even though C showed ~450GB free space. Is there still a way to partition as I intended? I don't want to jeopardize the existing system in any way after the trouble I went through with the >200 Windows updates. Thanks for your help.
  2. Posts : 72,062
       #441
    Hello lc007, :)
    Please go ahead and post a screenshot showing the full layout of your disk in Disk Management to see what options you may have.
  3. Posts : 14
    Please have a look. I only have the 100MB system reserved other than the main drive.
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-disk-c.png
  4. Posts : 72,062
       #443
    I don't see anything in the screenshot that would be an issue.
    Depending on what size you have set for your page file and system protection, those would be allocated on the C: drive and will not be allowed to be used to shrink for a new partition.
  5. Posts : 14
    Thanks for the reply Brink. Yesterday I tried playing with the system protection settings. Even after I disabled it, disk management still only allowed me to shrink ~230GM for the new partition so I promptly enabled it again. I don't know about the page file settings but reading through the "How to Free Up and Recover Hard Drive Space in Windows 7", I felt I don't want to mess with it either. I guess I'm just surprised that the OS could use so much hidden disk space. Now I'm curious: had I partitioned the C: drive to only 100GB during installation, what would the OS do about the page file and system protection stuff - adjust them to use less space or use D: drive anyway?
  6. Posts : 72,062
       #445
    The page file would remain on C unless you change it. Then the page file is managed by the system, it'll automatically increase in size as needed.
    Virtual Memory Paging File - Change
  7. Posts : 14
    Hello Brink, I realized that I should have read the other tutorial "Partition or Volume - Shrink" for my problem. I understand now I have to use a third party software such as partition wizard to shrink my C: drive beyond what disk management allowed. Now my question is: should I Create an Image Backup (another of your wonderful tutorials) before or after the partition? Thanks!
  8. Posts : 72,062
       #447
    I'd wait until afterwards, so that you'll have the latest version. :)
  9. Posts : 14
    Done!!! Many thanks. Moving on to backup.......
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-after.png
  10. Posts : 2
    hello someone can help me how to make new disk i have only 1 disk i mean disk 0 then drive e d c in disk 0
    i want my hdd config like disk 0 : c disk 1 : d disk 2: e
