Disk Management - Post a Screen Capture Image
  1. Posts : 19,383
    Thanks Koolkat!
  2. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Just linked this great tut, hopefully the OPs will read Step 5.
  3. Posts : 6,458
       #12
    Very nice - and I just found it two days after creating a post template.
    One Two suggestions
    - ask folks to close the left and right panes so more information is presented
    - ask folks to drag the horizontal pane bar up or down to present as much info as possible - lots of people have many drives.
    --> if it won't all fit on one screen shot - two will have to do - one of the top pane and one of the bottom pane
    Last edited by Slartybart; 26 Dec 2013 at 12:01. Reason: cool - manage attachment placement! Helps to read some of this stuff
  4. Posts : 19,383
    Thanks for the feedback - I'll add your suggestion tomorrow.
  5. Posts : 6,458
       #14
    You're welcome. I just updated the post (you're quick!) - added multiple screen shot stuff.
  6. whs
       #15
    Hi Colin, just saw this tut for the first time (kind of late - I am slow, LOL). It is great and now I don't have to make the whole story with my own postings. I bookmarked it. Thanks a lot, unfortunately it is too late to send reps your way.
  7. Posts : 19,383
       #16
    Thats OK WHS - as long as you find it useful, thats good enough
  8. Posts : 1
    Win7 HomePremium 32bit
       #17
    nice tutorial
  9. Posts : 6,458
       #18
    Try this as an alternative screen - it shows the disks (top) and the volumes (bottom)
    Save DMdiskman.zip to your desktop
    Open the compressed folder and Extract all
    Accept the defaults on the Extract dialog
    a new Explorer window will open showing the unpacked files
    You can move the DMdiskman folder to your start menu later if you wish
    When you launch DMdiskman, you'll see:
    The only thing you might have to adjust is the spacing betweent the top and bottom panes (many disks, many volumes). You want to show everything that can be shown (all disks, all volumes)
    The nice thing about this is that it shows how the disk is initialized (MBR / GPR) - thanks Edwin!
    and everything should be set for the user to post the screen shot (L & R panes closed, columns expanded...)
    Maybe a method 2 Colin?
    Bill
  10. Posts : 35
       #19
    Hi; I think I did this correctly.
    Thanks!
    Attached Thumbnails Attached Thumbnails Disk Management - Post a Screen Capture Image-capture.png
