#40
Yup that was it. Thank you very much.
Can't believe I forgot to do that.
Thanks again! Keep up the good work :)
help please at firs i could change win. themes like at step 3 ,but now i can't anymore i did some thiing an now it's like at step 7 and still from there i can't change my Win. color...((
Hello Jovan, and welcome to Seven Forums.
Double check each item (links) in the red warning box at the top of the tutorial to make sure you meet the requirements to have Aero enabled. :)
i checked everything in the red Warning box my PC-s ok i just don't know what hapend ,i was playing a game and the game stoped working and to exit i presed alt+F4 a few times an then i saw my task bar being white not the color it was before and now when i put the mouse pointer on a opened folder or etc. it shows me this in the image instead of showing me how a folder should look like. Hope the pic. helps you to solve my problem
Jovan,
From your screenshot, I see that Aero transparency is enable since your taskbar is transparent. It looks like you have disabled taskbar thumbnail previews. You might give one or more options in the tutorial below to enable it a try to see if it may help.
Taskbar Thumbnail Previews - Enable or Disable
i tried to change it like in that tutorial but it didn't work any other sugestions??
jovanD
You're using the windows basic theme.
Did you try using any aero theme and see if the previews come back?
Try the troubleshoot for aero:
(1)Click on the Start
(2)Type in Find and fix problems with transparency and other visual effects.
Troubleshoot and see if that gets back your aero.
Thank you Yussi. I forgot transparency is still available in the "Windows Basic" theme. I agree. It looks like jovanD needs to use an Aero theme.
Theme - Change or Save
Why is the taskbar colors on the right and left darker? Is there a way to correct that? I tried the color mixer, but nothing did it.
