Theme - How to Apply Custom Themes
Page 13 of 14 FirstFirst ... 311121314 LastLast
  1. Posts : 166
    windows 7 ultimate 64 bit
       #120
    Rose1 said:
    Ok I installed the luna theme and did everything the universal patcher and paste it on themes, but its no in the personalization saved themes.
    To install 3rd party themes,first you have to install:
    1.Universal Theme Patcher
    2.Theme Resource changer.
    You can find the above in deviantart,with lots of custom themes......
  2. Posts : 416
    windows Ultimate
       #121
    Where can I download the theme resource changer
  3. Posts : 72,098
       #122
    Hello Rose,
    If you like, Universal Theme Patcher is what the tutorial uses on the first page. It has a download link available in it. :)
  4. Posts : 166
       #123
    If you download any theme from deviant art,it includes theme patcher and resource changer along with theme setup.Simply unzip,install the theme after installing these two.
    Remember,theme patcher for installing third party themes,and resource changer for change visual styles of taskbar, startmenu and windows appearance.
  5. Posts : 416
    windows Ultimate
       #124
    Brink said:
    Hello Rose,
    On my custom theme the taskbar icon have some kind of shadow when I click on them. Anyway to fix that?
  6. Posts : 72,098
       #125
    I'm not sure how to Rose, but you might see if this may be able to help. You may be able to change the shadow images in it to be the same as the clear ones.
    Taskbar Button: Change Color of Orange Flashing Button
  7. Posts : 416
    windows Ultimate
       #126
    Mine is not orange though its glossy and when I double click it it has a shadow.
  8. Posts : 72,098
       #127
    Yeah, I was thinking change the icons above the orange one to be the same as the clear one right below the orange one instead may do the trick.
  9. Posts : 416
    windows Ultimate
       #128
    I don't think this is what I'm looking for.
  10. Posts : 3
    Windows 7 sp1 64 bits
       #129
    hello,
    The theme I installed works pretty well with your tutorial.
    However, I have some images that do not appear. (I did it on 2 different computers under Windows 7 SP1 64-bit) but nothing happens.
    The picture should give me the theme:
    See to rate the red arrow (the picture that I should have)
    I get me:
    See to rate the red arrow (She does not appear on my theme)
    All Appear exception is the image (background image of window)
    Thank you for helping me!
    I said that I already try with several different theme and the problem and the same.
