#660
You will need to create a bootable .iso from the downloaded files and burn to dvd/flash.
Boot the dvd/flash drive and install.
You may find this a very easy way:
Bootable ISO - Easily Create from Installation Files
You are super awesome. I have a scratched windows 7 disk that would install from within windows but couldn't boot from disk. This trick allowed me to fix it.
Great ninja,
I am pleased you now have a bootable disc.
I have a bootable DVD. Is it possible to use this to create a bootable USB?
As far as I can tell, there is no .iso on the bootable DVD.
Thanks.
Tipsy
Hi Tipsy,
You can install the free ISO Recorder v3
You don't see anything after you install it - rt click on the dvd drive and select "Create image from cd/dvd". That will create an iso image for you.
You could also use this free app. to make a bootable usb stick directly from the files on the dvd:
WinToFlash - Install Windows from usb - Home page
Video tutorial WinToFlash : Make a Bootable USB Installer for ...
