Make bootable iso from student d/l
Page 68 of 69 FirstFirst ... 5866676869 LastLast
  1. Posts : 7
    Windows 7 Pro 64-bit
       #670
    I can't get this to work... I get everything set up and then when I go to use the admin cmd it doesn't work... This is the message I get:
  2. Posts : 13,354
    Windows 7 Professional x64
       #671
    Welcome!
    See this post: Make bootable iso from student d/l
  3. Posts : 7
       #672
    Jonathan_King said:
    Welcome!
    Thanks I copied what he put at the bottom of the page and it worked! Thanks!
  4. Posts : 1,939
    Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
       #673
    What message???????????????????????????????????????????????????????????????????
  5. Posts : 13,354
       #674
    Somehow that part got deleted. Basically he had the syntax wrong.
  6. Posts : 1,939
       #675
    Oscdimg.exe –u2 –b"C:\Users\your_username\Desktop\expandedSetup\boot\etfsboot.com" –h "C:\Users\your_username\Desktop\expandedSetup" C:\7.iso
    This is to compare to his screenie...
    VERY STRANGE ERROR...
    The only thing I can think of from the error message is that perhaps you dont have the expanded setup folder on your desktop??? Is it?
  7. Posts : 13,354
       #676
    The spacing is a bit funny in the original tutorial, but the user that posted below corrected it.
  8. Posts : 1,939
       #677
    I think the screenshot image is distorted...
    The O in oscdimg looks like an 0... but it wouldnt have run if that was the case. Instead he'd get "Bad Command or Filename".
  9. Posts : 1
    Thanks, Audio, it worked for me, 2
    Audio said:
    My mistake there is suppose to be no space between -bC:\User
    Just there is suppose to be no space in etfsboot.com
    I end up making my own line to use
    oscdimg -bC:\Users\USERNAME\Desktop\expandedSetup\boot\etfsboot.com -h -u2 -m -lWIN_EN_DVD C:\Users\USERNAME\Desktop\expandedSetup\ C:\7.iso
    That worked for me
    I tried to use the instructions that were posted by SIW2, but it didn't work. YOURS DID............thanks!!!!
  10. Posts : 16,163
    7 X64
       #679
    There's nothing wrong with the tutorial instructions. It might be the forum is spacing them differently when you copy and paste.
    Glad you got it working. :)
      My Computers
