Repair Install
  1. Posts : 225
    The day I switched over from XP to 7, I always missed the "Repair" option that XP gave in its text based setup. I remember, I posted on several forums seeking help on how to "repair" Windows 7, it's a shame that, today, ie, 15 Apr 2013, after even Windows 8 rolled out, I got to know that Windows 7 CAN be repaired. Awesome tutorial. :)
  2. Posts : 222
    Windows 10/Windows 7 (My Idea- Virtual PC)
       #1281
    This is a very good post - I appreciate it. Mostly I do either system Restore or In-Place install from the Desktop.
    Yesterday, Malwarebytes released an update that rendered about 15 Windows 7 machines I maintain wholly unbootable, I was able to fix all of them save one, which had no restore points. There was really nothing I could do - Even Windows 8's Black Screen of Death allows you to hit Ctrl-Alt-Del "Three Fingered Salute" to pull up the Task Manager and you can re-run Setup from there. But windows 7 cannot be fixed that way.
    So - My question is, is there ANY version of the Windows 7 Install disk, x86 and x64, SP1 and No SP1 - That can do the in-place install from BOOT?
    This is the big problem with Windows 7, XP is easily repaired from the Install Disk, but Windows 7, it appears that an In-Place install can only be performed from the Desktop.
  3. Posts : 72,073
       #1282
    Hello Jonny,
    Unfortunately, it is true that a repair install can only be done from inside Windows 7.
    Do you have a system image available to restore?
    If you like, you could use either tutorial below to copy any needed files from the PC before reinstalling.
    Hope this helps some, :)
  4. Posts : 1,633
    Win 7 Ult SP1/Win 10 Pro (all x64)
       #1283
    Couldn't you even boot into Safe Mode? Malwarebytes is totally functional in that mode and you could then undo whatever MBAM removed. Assuming the quarantine hadn't already been emptied manually. I use MBAM and haven't seen anything like that happening. But the difference maybe that I don't use the "Pro" aspect of it as I already have A/V active.
  5. Posts : 243
    Windows 7 Professional 64 bit SP 1
       #1284
    I using a USB to try to do this repair install, but i cannot even boot into windows at all. I getting error of 0x0000007b. Yesterday my computer was fine, i was just doing a project and today when i open i get this error when i choose the option, disable automatic restart. So what can i do to fix this?
  6. Posts : 72,073
       #1285
    Hello Maul,
    Unfortunately, you can only do a repair install from within Windows. It cannot be done using any other method.
    You might see if this below may be able to help with the stop error 0x0000007b though.
    Error message occurs after you change the SATA mode of the boot drive
    Hope this helps, :)
  7. Posts : 243
       #1286
    Brink said:
    Hello Maul,
    Hope this helps, :)
    I notice already, I read through again the post.
    Okay, thank you, anyway, I directly reformat my PC already, no choice by that time :)
  8. Posts : 72,073
       #1287
    I hope it went smoothly for you Lee. :)
  9. Posts : 13
    My installation stopped at the "expanding files" part... Can someone plzzz help.
    Screenshot of error below...
  10. Posts : 72,073
       #1289
    Hello GiCommando,
    What are you using to do the repair install with?
