Repair Install
  1. Posts : 72,062
       #1910
    Hello jjsjjs,
    I'm afraid that it looks like you may need to clean install instead.
    Clean Install Windows 7
  2. Posts : 3
    Windows 7 Ultimate x86
       #1911
    Hi Brink thank you for your reply :)
    oh oh that's what i'm afraid of too...
    I noticed that outgoing POST to the php script is working ok as i checked the database with phpmyadmin and saw that what i had send was written in it.
    So conclusion is there is something other than the firewall blocking incoming data.
    Any suggestion on that before i do a clean install ?
    Thanks very much.
  3. Posts : 72,062
       #1912
    I'm not aware of anything else.
  4. Posts : 3
       #1913
    Ok thank you so far. i appreciate it ! :)
  5. Posts : 118
    Win 7 Ultimate x32, x64, Win 7 Pro x32, x64 Win 7 Home x64, XP Pro sp3
       #1914
    I ran a repair install from the hard drive after copying all files out of an ISO. It is currently asking for a Key. The keyboard and the mouse don't work. This is a Laptop Lenovo W550s I have tried:
    1. Plugging in an external USB keyboard and re-booted.
    2. Plugging in an external USB mouse and re-booted.
    3. Booted from a CD with Win 7 (The same version that is installed)
    I get to the Compatibility Report and it says: "The computer started using the Windows installation disk. Remove the installation disk and restart the upgrade."
    The Keyboard and the mouse work just fine to start the install.
    If I boot from a USB bootable CD the keyboard and mouse work just fine.
    How can I get the repair install to recognize the keyboard?
    Thank you,
    Docfxit
  6. Posts : 72,062
       #1915
    Hello Docfxit, :)
    If you have selected to do an upgrade from within Windows 7 and not at boot, it shouldn't be asking for a product key if the Windows is currently activated, and if the installation media is the same edition, version, and language you currently have installed.
  7. Posts : 118
       #1916
    Thanks for the reply...
    This installation has Windows is currently activated, and I believe the installation media is the exact same edition, version, and language I currently have installed. I believe there is a file in the setup folder that shows exactly what is being installed. How can I find that file?
    Thanks,
    Docfxit
  8. Posts : 72,062
       #1917
    You could check the Windows setup logs to see if anything stands out.
    https://technet.microsoft.com/en-us/...(v=WS.10).aspx
  9. Posts : 118
       #1918
    I found a way to determine what version of the OS is being installed from the ISO file.
    dism /Get-WimInfo /WimFile:E:\sources\install.wim /index:1
    My results show:
    Index : 1
    Name : Windows 7 STARTER
    Description : Windows 7 STARTER
    Architecture : x86
    Hal : acpiapic
    Version : 6.1.7601
    ServicePack Build : 17514
    ServicePack Level : 1
    Edition : Starter
    Installation : Client
    ProductType : WinNT
    ProductSuite : Terminal Server
    System Root : WINDOWS
    Directories : 9105
    Files : 46887
    Created : 11/20/2010 - 3:26:11 PM
    Modified : 11/20/2010 - 6:16:15 PM
    Languages :
    en-US (Default)
    The operation completed successfully.
    I'm surprised to see Windows 7 STARTER
    I expected to see Windows 7 Ultimate
    I have attached the setuperr.log file.
    I'm wondering if one problem might be the R: drive. In windows normal operation I have a ram drive that is created for my temp files. The error log shows the R: drive failed.
    Thanks,
    Docfxit
  10. Posts : 72,062
       #1919
    Does it show "Windows Starter" in System as well? If so, then the installation media will need to be the same.
    System Shortcut - Create
    It wouldn't hurt to not use the RAM drive for your temp files during the repair install to see if it may help.
