Process Explorer + VirusTotal (to check all processes with 50+ AV's)
Process Explorer by Sysinternals(Microsoft) is a more advanced alternative to Windows Task Manager
VirusTotal.com is a multi-engined scanner service from Google with more than 50 different anti-virus products including:
AVG, Avast, Avira, BitDefender, ESET, F-Secure, GData, Kaspersky, Malwarebytes, Microsoft, Norman, Panda, SUPERAntiSpyware, Sophos, Symantec, TrendMicro and many more.
The VirusTotal integration in Process Explorer is very fast because it only sends file hashes, a unique content identifier, and not the files itself. It's dependent of previous scans on VirusTotal for every specific file and version, but because VirusTotal is a heavily used worldwide service you often get fresh results for most files.
1. Download Process Explorer from its homepage: Process Explorer
or use the direct download link
Download
2. Extract the contents from the ZIP file preferably to a new folder. If you don't have a 3rd party Zip program you can use the Windows built-in function: right click the Zip file and select "Extract all..."
3. Double-click the file procexp.exe
The new column VirusTotal will be added automatically, and initially show "Hash submitted...". After a few seconds it will show the result:PE VT standard.png
5. Processes that run as System and not as standard user, won't show a VirusTotal result until we restart Process Explorer with elevated permissions:PE admin launch.png
If you get a UAC prompt click Yes. Now, after a few seconds, we will see the VirusTotal result for every process:PE admin.png
A VirusTotal result of 0/55 means that 55 anti-virus products have checked the file and that non of them detected anything!
Click the result/link to open the detailed report in a web browser. There you'll find when the scan was done and other useful information like what anti-virus products detected anything and what type of possible infection/malware.
Example of a VirusTotal detection:
If only one AV detected something chances are that it's a "false positive" (wrongly detected) and that the file is clean. Click the VirusTotal link to get more details about it.
6. If you have processes that show "Unknown" in the VirusTotal column, it means that specific file and version has never been uploaded to VirusTotal. To automatically upload these files to VirusTotal select this option:PE submit unknown.png
7. To submit a file to VirusTotal manually, any file (not only "Unknown" ones), which means to upload and re-scan the file, double click a process, go to the Image tab and click this button:PE submit one.png
You can then exit the Properties window and wait until you see a result in the VirusTotal column for that process. It'll take a few minutes.
8. You can also do a VirusTotal check for all the DLL files a process uses. Select a process and press Ctrl+L to toggle the lower pane. It will submit the file hashes to VirusTotal and show the result after a few seconds:PE lower pane.png
If the VirusTotal column isn't shown in the lower pane, right-click a column header to select columns
If other files than DLL's are shown, go to menu View - Lower Pane View - and select DLLs
9. If you find more than one suspicious process and want to terminate them, it's recommended by Mark Russinovich, the author of Process Explorer, to first suspend(right click option) them. As many malware infections include multiple processes they can easily restart each other when only one is killed, so suspending them first is a safer way.
More info: Managing Risk
10. If you like Process Explorer you can easily replace Task Manager with it:PE replace TM.png
11.
If you want you can also verify image signatures. You do this by selecting "Verify Image Signatures" from the Options menu. In the screenshot above you can see how it looks like when that option is checked, the second row in the drop-down Options menu. When you select this option you'll see a new column in the process list: "Verified Signer". Example: PEverified.png
An unsigned software doesn't mean it's bad, but it may be more suspicious. Besides looking for unsigned or revoked signatures, also look out for empty or strange names (also in the columns Description and Company Name)
12. Another useful feature is "Process Timeline". To add it go to menu View - Select Columns... then go to tab "Process Performance" and select "Process Timeline".timeline.png
The green part indicates how long a process have been running. So in the above example all processes have been running since start except these that have been started in this order:
- iexplore x 3, started just after the start of Windows
- firefox
- procexp, recently started (almost no green visible)
So how can this information be useful?
Example: Let's say you start a browser and end up on a web site that has a drive-by-download that is able to start a new process. You can then check process timeline for any processes that has started after the browser was started.
You won't see details for all processes until Process Explorer is run as Administrator!
The default colors used in Process Explorer are set in the Options menu - Configure colors. Not all colors are used by default, so if you want you can enable the unchecked ones too:
Most programs are not "packed"(purple color) which can mean they are obfuscated or encrypted, so watch out for those as they would probably be more suspicious than other processes!
This Tutorial has showed you how to check all running processes. If it finds any malware it means it's already running on your system. To try and prevent new malware from infecting your system I recommend my other Tutorial mentioned below. It's an easy way to check downloaded software before running or installing them.
Very well done. :thumbsup:
Windows 10 ProAMD Ryzen 5 2400G Processor with Radeon RX Ve...G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-P...2047MB NVIDIA GeForce GTX 1060 6GB (EVGA)
Windows 10 Pro
Motherboard Built in
Wired Dell keyboard
Wireless Logitech mouse
250mb down, 30mb up
Panda Cloud Antivirus
Chrome-ish x64
Ok mate it is going to take me a few reads to rally get the hang of this but it sounds such a good tool to have.:)
1920x1080 D1 & D2 & Laptop 1
Desk1 Samsung 120GB 830 SSD
Asus ROG 256GB 850 Pro SSD
Desk2 Samsung 840 256 SSD
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Update: added info on how to verify image signatures (step 11)
Windows 7 Pro 32Intel(R) Core(TM) i5 CPU M 540 @ 2.53GHz4,00 GB (Usable 2,98)NVIDIA NVS 5100M
HP Elitebook 8540p
Windows 7 Pro 32
Hewlett-Packard 1521
NVIDIA NVS 5100M
NVIDIA High Definition Audio
1600x900
INTEL SSDSA2CW120G3
F-Secure Internet Security
IE, Firefox, Opera
Sandboxie,
SRP (Software Restriction Policy),
EMET (Enhanced Mitigation Experience Toolkit),
WFC (Windows Firewall Control by BiniSoft),
Malwarebytes Premium
Update: added info for "Process Timeline" (step 12) + minor improvements
HP Elitebook 8540p
Windows 7 Pro 32
NVIDIA NVS 5100M
1600x900
INTEL SSDSA2CW120G3
IE, Firefox, Opera
Sandboxie,
Hey, thanks very much for all this information, especially the Process Timeline!
Windows 7 x64 Pro, Windows 8.1 x64 Pro, Windo...
Windows 7 x64 Pro, Windows 8.1 x64 Pro, Windows 10 TP 10041
How can I use this program to find out why my PC will not go into sleep mode?
Windows 7 Home Premium 64bitIntel core i58GBAMD Radeo HD 7700 series
Puget Systems
Intel core i5
ASUSTeK Computer INC. P8Z68-V PRO GEN3 (LGA1155)
8GB
Acer Al2002W
500GB
298GB Western Digital WD 3200AAJ External
2794GB Western Digital WD My Book 1230
Antec TruePower New Series 650W
Lancool C-K7B
Cooler Master Hyper TX3
windows security essentials
IE10, Firefox
