Open Application Toolbar and Context Menu Icon - Fix
Page 7 of 8 FirstFirst ... 5678 LastLast
  1. Posts : 3,302
       #60
    Achilleus said:
    xxxdannyxxx said:
    Okay
    Just to check.
    - You didn't rename the .ico file did you and it is unblocked
    - For sure its in C:\Windows\System32
    - You merged the .reg file and rebooted/Logged on-off
    You could manually check in regedit that the key is there and is identical to the manual method in Shawns tutorial. If all the above is correct rerun the icon cache rebuild just to be sure.
    To be honest I'm out of suggestions. Brink may be able to add something when hes online later as he created the tutorial.
    Sorry mate I see no reason why it wouldn't have worked for you.
    Double check the above and let us know.
    At last, it worked like a charm.
    I knew it, I had done this fix many times on my 32bit OS, but I stumbled when I found I can't fix it as before. It was tricky. I was using Tera Copy as my Copy handler. I thought I copied Application_icon.ico to system32, when I was rechecking the file by pasting the file again, Tera Copy shows that the file already exists in System32 and asks me whether it wanted to overwrite it. So, I was sure, the file really exists there. But, when I checked System32 folder manually, the file doesn't exist! I was & ! Then I disabled Tera Copy and used the default Windows file copy handler & the file copied without any prompt to overwrite it.
    Then I killed the Explorer.exe process and started it again. Voila!!!
    The problem solved. But, I'm still confused with Tera Copy's response. Why it didn't copy the file and asks me to overwrite the file which in fact the file doesn't exist.Unusual!
    Thanks to Danny & Brink for helping me.
    Again, Brink, you're doing a fantastic job as Microsoft Valued Pro & being Site's Admin.
    Take Care
    Thats good news not only for you but for my sanity also
  2. Posts : 476
    windows 7 ultimate 64bit
       #61
    wow
    thanks
    but why does it happen ?
    i mean no icon for exe
    is normal? or my w7 is not healthy
    i asked here explorer , open exe without icon , is it normal?
  3. Posts : 72,052
       #62
    Hello Drugo,
    It's just that way by default in Windows 7. It's a minor little bug.
    The first icon in the icon library of the default file that Windows 7 uses for this icon just happens to be that one. The tutorial uses a workaround to change this so that it will use the "Application_Icon.ico" instead. :)
  4. Posts : 476
       #63
    Brink said:
    Hello Drugo,
    thanks Brink, you are number one!
    microsoft should pay you gold
    do you think future hotfixes would fix it?
    for now i use your great fix!
    again can't give you reputation
    thanks
  5. Posts : 72,052
       #64
    You're most welcome Drugo. It might get fixed one day by an update. :)
  6. Posts : 53
       #65
    Alternative version with empty context-menu (just "Open") and program icon for the toolbar. More standard look
    Copy dummy_icon in C:\Windows and set it as
    [HKEY_CLASSES_ROOT\exefile\shell\open]
    "EditFlags"=hex:00,00,00,00
    "Icon"="%WINDIR%\\dummy_icon,-17"
    Open Application Toolbar and Context Menu Icon - Fix Attached Files
  7. Posts : 72,052
       #66
    Thank you for the addition hexaae. :)
  8. Posts : 3
    Windows 7 Home Premium 64 bit
       #67
    Add path to .ico file in registry key
    Brink (or anybody else who knows)
    When adding the path to an .ico file (or to an icon in an .exe or .dll file) in the registry key; for example in step 8 of the tutorial it says something like:
    NOTE
    : If you like, you could also enter the full path of a different icon (.ico file) that you would like to use instead with ",-1" (no quotes) at the end like below.
    %Windir%\System32\Application_Icon.ico,-1,
    or you might use
    %Windir%\System32\imageres.dll,-15
    Why do you put a minus sign ("-") in front of the number that is the icon number in the file?
    I've used IconViewer to look thru many .exe and .dll files in search of icons and — while the icons almost always have a number (some just say mainicon instead of having a number) — I've never seen an icon number with a minus sign in front of it.
    Also, I've seen other Icon entries in the registry that have a positive number, or 0, or no number at all.
    For example:
    Icon............. REG_SZ......... explorer.exe,9
    (Default) ..... REG_SZ......... C:\Program Files\WinRAR\WinRAR.exe,0
    Icon............. REG_SZ......... regedit.exe
    So....... Why the minus sign ?
    Thank you.
  9. Posts : 72,052
       #68
    Hello modernmaid,
    I just like using the minus to specify the icon to use. Usually not specifying to use the main (default) icon of the file is fine though. Just a personal preference. :)
  10. Posts : 1
    Holy... ive had this stupid little nagging problem for over a year now... just chalked it up to being broken and tried to move on... thank you, thank you!
