Offline Files - Enable or Disable the Use Of
    Enable or Disable the Use Of Offline Files in Windows 7 and Windows 8
    If you work with files on a network, you can make the files available offline so you can access them even when your computer is not connected to the network. This is especially useful if you use a laptop to connect to a workplace network.
    When you make a network file, or all files in a network folder, available offline, Windows creates a copy of the file or folder on your computer. This is called an offline file. The next time you disconnect from the network, you'll still be able to open, modify, and save the file the same way you would if you were still connected. And when you do connect to the network again, Windows will automatically sync the offline file on your computer with the corresponding file on the network to update it.
    This tutorial will show you how to enable or disable the use of offline files for all users on the computer in Windows 7 and Windows 8.
    You must be logged in as an administrator to be able to do the steps in this tutorial.
    In Windows 7, offline files is only available in the Windows 7 Professional, Ultimate, and Enterprise editions.
    In Windows 8, offline files is only available in the Windows 8 Pro and Windows 8 Enterprise editions.
    Here's How:
    1. Open the Control Panel (icons view) in Windows 7 or Windows 8, and click/tap on the Sync Center icon.
    2. In the left pane, click/tap on the Manage offline files link. (see screenshot below)
    3. To Enable the Use of Offline Files
    A) Click/tap on the Enable offline files button. (see screenshot below)
    B) If prompted by UAC, then click/tap on Yes.
    C) Click/tap on OK. (see screenshot below)
    D) Go to step 5.
    4. To Disable the Use of Offline Files
    A) Click/tap on the Disable offline files button. (see screenshot below)
    5. Click/tap on Yes to restart the computer. (see screenshot below)
    WARNING: This will restart the computer immediately. Be sure to save anything that you have open first.
    6. If you enabled Offline Files, then all you need to do now is to make the network files or network folders you want to be always available offline.
  1. Posts : 4
    Vista
    does this work in home edition or is the function disabled ??
  2. Posts : 72,052
    Hello Busaboy, and welcome to Seven Forums.
    Offline Files is not a included feature in Windows 7 Home Premium edition, so it will not even be an available option for you. It's only available in the Windows 7 Professional, Ultimate, and Enterprise editions.
  3. Posts : 4
    Vista
    OK Brink
    Looks like an upgrade then
    Thanks for your reply
    Andy
  4. Posts : 72,052
    You're welcome Andy. Sorry you will have to upgrade.
  5. Posts : 4
    Vista
    All upgraded and working proprly now
    Thanks a lot
  6. Posts : 72,052
    That's great news Andy. I'm happy to hear that you got it sorted. :)
  7. Posts : 20
    Thank you so much for this Brink. I have been through every blooming tutorial I could find to get rid of my unwanted sync files, then I came across this post,
    Thank you so much .
  8. Posts : 72,052
    You're most welcome Mick, and welcome to Seven Forums. :)
  9. Posts : 20
    Thank you Brink :)
