Taskbar Button Grouping - Enable or Disable
Page 5 of 7 FirstFirst ... 34567 LastLast
  1. Posts : 4
    windows xp
       #40
    i search for this but none of the program or change in register made that i wont.
    thx anyway.
  2. Posts : 3
    Windows 7 64bit
       #41
    I have a similar but different problem. Unlike the initial tutorial on page one of this thread, I need to know how to achieve the attached result. I use 2 computers running windows 7, one displays like the attachement when I mouse over the IE button, and the other dispalys the open IE pages side by side like the initial examples. How do you change between those modes?
    Thanks,
    Jordan
    Attached Thumbnails Attached Thumbnails Taskbar Button Grouping - Enable or Disable-windows-7-taskbar.jpg
  3. Posts : 72,103
       #42
    Hello Jordan, and welcome to Seven Forums.
    You can use the REG downloads in OPTION ONE of the tutorial below to switch between having the taskbar use "list mode" like in your screenshot, and the default thumbnail previews mode.
    Taskbar List or Thumbnail Previews Mode - Change
  4. Posts : 3
    Windows 7 64bit
       #43
    Thanks. I will try that. I tend to like the method I attached better...but I use the 2 machines differently. So, I will apply that on the other machine, and see how that works for the work I do on that machine. I always have a ton of things going on, hence the ability to stack and keep it neater. Thanks again for the quick response. You would think it was be a simple toggle somewhere within Windows, I guess I was wrong.
  5. Posts : 72,103
       #44
    You're most welcome Jordan.
    In addition, if you like, you can use step 3 in OPTION TWO to set how many thumbnail previews to display before it automatically displays list mode instead.
  6. Posts : 4
    Windows XP / Vista / 7
       #45
    If you like seeing a list of open program names (titles), I would also suggest trying the taskbar at the left or right edge of the screen. Set the width of the taskbar to accomodate enough text of each title to satisfy you. Assuming that your taskbar is in Auto-Hide mode, just popping up the taskbar will show you your list of programs.
    I launch most of my programs from the "Desktop" toolbar on the taskbar (right-click on the taskbar, then select Toolbars->Desktop), keeping the taskbar wide enough for three columns of icons (they can be arranged on the toolbar).
    Bottom line, I've never used the taskbar at the bottom, and given the features removed in Windows 7 I purchased a copy of ClassicStartMenu (SevenClassicStart is another one).
    The neat thing about ClassicStartMenu (not a perfect program, but hey, if Microsoft hadn't removed features I wouldn't have needed it) is that I can choose to click on either the ClassicStartMenu button and get my pre-Windows 7 look and feel, or I can click next to it and get the Windows 7 start menu, which is okay when you know the exact word to search for.
  7. Posts : 16
    Windows 7 Home Premium 64Bit
       #46
    Nice post, but I like them grouped. Keeps them organized when I have a lot of windows open. All I have to do is just click on the tab and scroll up to which ever window I want. Better than minimizing this and that.
  8. Posts : 2
    7 hp 32
       #47
    My problem is that I can't use option of taskbar buttons grouping because I haven't got active posibility to change options like on (3) of taskbar icons when I try do that by making like (1)
    WHY????
    Can you help, that is nice new way in 7 that I can't use
  9. Posts : 72,103
       #48
    Hello Modrzew, and welcome to Seven Forums.
    Double check with the tutorial below to make sure that you have this "Allowed".
    Taskbar Button Grouping - Allow or Prevent
  10. Posts : 2
    7 hp 32
       #49
    Great, that's works, thank You
