Icon Cache - Rebuild
Page 27 of 31 FirstFirst ... 172526272829 ... LastLast
  1. Posts : 1
    Windows 7 Ultimate X64
       #260
    You don't have to restart after using Icon Cache Rebuild. Mine disappeared along with my taskbar and nothing was happening, so I hit ctrl+alt+del, then start task manager. Next click "File" then "New Task (Run) and type: explorer.exe then click ok. All my icons were restored.
    Last edited by michaell369; 27 Jan 2016 at 04:46. Reason: I forgot a seemingly important detail.
  2. Posts : 72,133
       #261
    Hello Michaell, and welcome to Seven Forums. :)
    Restarting the computer is required to have the deleted %localappdata%\IconCache.db file recreated.
  3. Posts : 87
    Linux Lite
       #262
    Can i do it in safe mode?
      My Computers
  4. Posts : 72,133
       #263
    Hello f234948, :)
    Yes, you sure can.
  5. Posts : 87
    Linux Lite
       #264
    ok cool thanks for the reply Brink
      My Computers
  6. Posts : 2
    Windows 7 Professional 64 bit
       #265
    Thank you- it fixed mine
    Thank you for the icon rebuild instructions.
    I too was suffering from a never ending scan in Windows Explorer and icons with no pictures after I did a Windows update. Following the manual instructions posted solved my issue.
  7. Posts : 72,133
       #266
    You're most welcome Jerry. I'm glad it could help. :)
  8. Posts : 87
    Linux Lite
       #267
    it gives me a error, i have tried everything like temporary disable antivirus, etc.,
      My Computers
  9. Posts : 72,133
       #268
    Hello f23948, :)
    That is normal for those few .db files, and nothing to worry about.
    Did rebuilding the icon cache and restarting the PC help with your icon issue?
  10. Posts : 87
    Linux Lite
       #269
    did restarted computer 3 times, and it's working now
      My Computers
