Built-in Administrator Account - Enable or Disable
Page 2 of 29 FirstFirst 123412 ... LastLast
  1. Posts : 1,289
    swarfega said:
    "NOTE: You could also type Control userpasswords2 instead if you like since it takes you to the same window under step 4." I think the wording needs clarification. Its not good grammar.
    Hey Swarfega,
    I updated the Tutorial, is it more understandable now?
  2. Posts : 4,925
    Windows 7 Professional 64-bit
    Yeah thats more understandable. I think there were too many words before.
  3. Posts : 72,052
       #12
    Thanks for the update Steven and Swarfega.
  4. Posts : 2
    windows 7
    Hi guys,
    Have just put windows 7 on my new machine,however the uac is driving me crazy.
    It has totally locked me out I have tried all of the above but to no avail.
    I just keep getting error messages without being able to proceed to the next step of being able to turn off uac.
    Any help would be greatly appreciated
  5. Posts : 795
    windows 7 RTM x64
       #14
    right-click on the my computer icon, and go to manage. click local users and groups, then users. right-click on the administrator account and click properties. Uncheck the box that says disable account. close the properties window, right-click on the account again and set a password. Reboot and you should be able to login as the administrator account.
  6. Posts : 2
    windows 7
       #15
    Many thanks worked a treat.
  7. Posts : 795
    windows 7 RTM x64
       #16
    glad i could help
    in case you didnt know you can just copy your documents and favorites into the admin profile, you dont need to move them somewhere else first. You will have to reset some program settings though (some store things in the user registry.)
  8. Posts : 2
    core 2 duo
       #17
    hello
    brothers i have a problem
    i have successfully unlocked administrator through command prompt......but sumhow my lil brother disabled it....now i can't unlock it. . .it asks for password. . i got pass but could'nt find the space to put it... . .plz help me out
  9. Posts : 72,052
       #18
    Hello retarded, and welcome to Seven Forums.
    If you are able to log on to your normal default administator account instead, then check with each method in the tutorial to see if your brother may have used it to lock/disable the built-in Administrator account.
  10. Posts : 795
    windows 7 RTM x64
       #19
    login with your "normal" admin accoun> then right-click on my computer> go to "manage"> go to local users&groups> go to users> right-click on "administrator" and click "change password" and set a new password.
    If you have any encrypted files under that account, they will not be accessible. But, this will get you into the account.
    Dont let your younger bro have admin rights, and dont leave the computer logged in unattended unless you lock it.
