Context Menu - Add Copy To Folder and Move To Folder
Page 6 of 11 FirstFirst ... 45678 ... LastLast
  1. Posts : 72,058
       #50
    You're most welcome onlytanmoy. :)
  2. Posts : 2
    Windows 7 Home Premium 32bit
       #51
    Many thanks.
  3. Posts : 72,058
       #52
    You're most welcome Macmandan, and welcome to Seven Forums. :)
  4. Posts : 25
    Windows 7 x64 Ultimate
       #53
    Move to
    Works great, just what I was looking for!
    THanks,
    dev
  5. Posts : 72,058
       #54
    You're most welcome Dev. :)
  6. Posts : 1
    win 7 Ultimate 64bit
       #55
    problems with install
    Followed directions but after pressing run a note pad window opens with the following
    "Windows Registry Editor Version 5.00
    [HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\{C2FBB630-2971-11D1-A18C-00C04FD75D13}]"
    but no further instructions or choices. I assume the key must be inserted in the registry but where?
    regards
  7. Posts : 8,679
    When you double click on the downloaded file,it should be opened with Registry Editor. Download this file to restore .reg file default file associations.
  8. Posts : 72,058
       #57
    regards
    Hello Captrip, and welcome to Seven Forums.
    It sounds like your REG file extension associations are messed up and are not letting you merge a REG file.
    Double check in Default Programs to set the reg file extension to have it's Current Default program set as Registry Editor (C:\Windows\regedit.exe). Afterwards, try merging the REG file from the tutorial again. :)
  9. Posts : 22,814
    W 7 64-bit Ultimate
       #58
    I see you have split the "Move To" and "Copy To" reg files up, mind if I ask why?
  10. Posts : 72,058
       #59
    Hello Ted,
    Not at all. I had many people ask to only have one or the other item added to the context menu instead of both, so I just split them to make it easy to add just one or both. :)
