Page 10 of 33 FirstFirst ... 8910111220 ... LastLast
  1. Posts : 72,150
       #90
    cmlow said:
    Brink said:
    cmlow said:
    , Is there any short cut to jump out from the Full Format to Quick Format?? Is it worth to do so?
    Yes, it would be the same procedure as you did to interrupt the "Clean All" command.
    Afterwards, run "Clean" again, then do the quick format. :)
    It is a great relief to hear this solution. I will try it out when getting home. Keep my finger cross.
    Thank you very much Brink.
    You're most welcome cmlow. :)
  2. Posts : 435
    Thanks for the help Brink, this might fix wireless problems: if not I will call Virginmedia, if that fails, I could try replacing Network cards.
    Cheers Joe.
  3. Posts : 72,150
       #92
    You're most welcome Joe. :)
  4. Posts : 21
    Windows 7 Professional 32bit
       #93
    No. It doesn't work Brink.
    I repeat what I have done.
    1. Clean
    2. Create partition primary size=152725
    3. Assign letter=C
    4. Active
    5. Format fs=NTFS Label="Local Disk" Quick
    6. Exit and Exit
    Then I go to system recovery to do Re-Image. Same error massage: No disk that can be used for recovering the system disk can be found
    Then I go to BIOS to change the boot priority to set HDD as first. Yet still the same error.
    What is wrong??
  5. Posts : 12,012
       #94
    What happens if you try this:
    clean
    create partition primary size=152725
    select partition 1
    assign letter=C
    active
    format fs=ntfs quick
    exit
  6. Posts : 435
    Hi Brink, it worked but now there is no Operating System and for some reason my External Disk Drive is broken (hardware not software) and it is a Netbook, so does not include DVD Drive, any ideas?
  7. Posts : 72,150
       #96
    1. Clean
    3. Assign letter=C
    4. Active
    6. Exit and Exit
    What is wrong??
    clean
    select partition 1
    assign letter=C
    active
    exit
    Do what Ignatzatsonic posted, but leave out the active command. Doing this may be why it's not able to use the disk since it was marked as active.
  8. Posts : 72,150
       #97
    Joe,
    If your netbook as a USB port, then you could create a Windows 7 installation USB flash drive on another computer to use to install Windows 7 with instead.
  9. Posts : 21
       #98
    Brink said:
    ignatzatsonic said:
    clean
    select partition 1
    assign letter=C
    active
    exit
    Brink
    It still don't work. I have tried both ,method one with active and one without active. It still failed to detect the disk.
    What other area you can think about is not set probably?
    Do you think the jumper at the HDD have to set as Master or cable something? But it already shown in BIOS that HDD is primary disk. Still don't understand what went wrong.
  10. Posts : 72,150
       #99
    cmlow,
    Do you have another computer (friends perhap) that you could connect the HDDs to, and try to format them from within their Windows?
