Page 19 of 33 FirstFirst ... 9171819202129 ... LastLast
  1. whs
       #180
    Layback Bear said:
    Wolfgang states he runs Vmware portable so he can go from computer to computer. That is if I understand what I think I understand.
    My question: How does this work when two different computers have completely different hardware and drivers, ect.
    Now remember I'm a dummy that doesn't use his brain so be easy on me.
    It does work because VMware shields you from the hardware specifics - try it you'll like it. And it can be done with any OS, not only Linux. I have a portable Win8 too. I do, however, recommend an external SSD - much more fun than a spinner.
    Btw: My 60GB SSD cost $59.95 and my 32GB high speed USB3 stick cost $65 and was so slow that I gave up on it.
    Portable OS - Carry your OS on an External Drive
    But if you want a portable Linux on a flash drive, I use a different approach. That works even with a USB2 stick - not super fast but acceptable. And it can come in handy.
    Emergency Kit - save your files from a dead OS
  2. Posts : 72,059
       #181
    If you like, you might stick with just creating a virtual machine of Windows 8 with VMware Player on a computer instead. It will be much simpler and less likely prone to issues that a portable version.
    VMware Player - Install Windows 8
  3. whs
       #182
    Right, that's what I recommend too. Create your virtual machine on your normal system. After all, it is only a folder that you find per default in Documents. Then, if you wish, you copy that folder to an external device and open it as virtual machine (connect to the .vmx subfolder) on any system where you have VMware installed. Very simple and straight forward.
  4. Posts : 25,847
       #183
    Thank you gentlemen.
    I have a lot of space on a hard drive but I looking into another internal SSD. I have always had great reliability with Intel so I'm looking. Seem like Intel is still pricey.
    I suppose the first thing I should look into and think about whether I want to put out the money for Windows 8.
    Microsoft doesn't seem to know whether it's going to be pro
    8.1 or 8.#?
    No touch screen here, I sit across the room from the screen.
    The last time I tried this when I downloaded VMware I got so much trash I didn't ask for it took me hours to remove all of the trash and search for more trash to make sure it was all gone. Then run all kinds of security scans.So I didn't get the VMware and just said the hell with it. I'm thinking.
  5. whs
       #184
    Download the VMware Player from Filehippo. That should be pretty clean.
    Download VMware Player 5.0.2 - FileHippo.com
    Regarding the SSDs - Intels are good. I have a couple myself since several years and they have never disappointed me.
  6. Posts : 25,847
       #185
    Thank you Wolfgang, Bookmarked.
  7. Posts : 14
    win7 Ultimate 64
       #186
    Thanks Brink, should have seen this before going out and purchasing a NOT so friendly Scrubber!!
  8. Posts : 72,059
       #187
    You're welcome DJ. Glad it could help. :)
  9. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #188
    Hi Brink I've got a holiday project and was seeking advice on how to deal with this Manufactures partition,
    Not at all sure what is on it did a re-install last holiday bat never really dealt with this I forget why I believe someone said leave it alone ?
    I would of rather merged and reformatted the entire C drive and made it more simplistic,
    Attachment 285502
    Attachment 285503 Attachment 285504
    Attachment 285505 Attachment 285506
  10. Posts : 72,059
       #189
    Hey Mike,
    Yeah, since you have plenty of free space on C:, you could wait until your ready to do a clean install next to delete all partitions on the disk during installation to then select the unallocated disk 0 to install to. That would be the easiest way.
    Otherwise, you would need to use a free program like MiniTool Partition Wizard Home Edition or EaseUS Partition Master Free Edition to move or merge the unallocated space into C. This would still not be a perfect solution as above though.
    Hope this helps some. :)
