#310
No mate I would attach it to another machine and use a USB to SATA adaptor/ USB dock or straight plug in .
But if he wants any data of it first then he can use this
BOOTABLE UBUNTU
Make a bootable Ubuntu disk https://www.ubuntu.com/download/desktop
Set the BIOS to boot from the optical when the machine boots it will show you a screen with TRY or INSTALL > select TRY not INSTALL
When it is finished - it takes very little time you will get a screen like in the pic .
Open the drive you want > User and dig down until you get to the data / settings you may be able to copy / paste the material you want to an external source or other installed drive doing this.
I am not sure if it will but I have recovered tons of data etc using this method both on "dead" or just plain drives that you cannot get data from using Windows.
Or there is this Emergency Kit - save your files from a dead OS I prefer Ubuntu a tad easier to set up but this does the same thing
You can hook the drive you want to clean in any fashion you care to. It would be the quickest it you used a Sata connection. You must be careful to make sure you pick the correct drive when you do a clean.
Jack
Hi there - if you personally don't see a difference between clean and clean all then pls see my 2 posts here - Disk - Clean and Clean All with Diskpart Command - Page 30 - Windows 7 Help Forums and Disk - Clean and Clean All with Diskpart Command - Page 30 - Windows 7 Help Forums or read Brink's explanation here - Disk - Clean and Clean All with Diskpart Command - Windows 7 Help Forums
You should, by now, know the difference between clean and clean all as it is rather substantial. Your chalkboard analogy is only applicable when we talk 1 pass vs 35 passes. But clean and clean all do 2 very different things so go ahead and see the links I referred you to.
As to the 'wipe', that you are mentioning - AFAIK 'wipe', 'secure erase', 'secure delete' and 'clean all' (but NOT 'clean') are one and the same thing essentially. So that's why nobody every compared wipe to anything in the discussion so far.
As to what you said - 'Windows will format the drive on installing itself onto the cleaned drive' - Windows does a Quick Format there and not a Full Format. I think those two can be likened to Clean and Clean All commands (they might even be the very same thing, dunno). So Windows's doing a Quick format is not much of help because this does not overwrite anything, it just marks data as to-be-overwritten. As I pointed out several times by now, you might easily have malicious data telling Windows never to overwrite it. So therefore hoping that Windows will automatically clean things for your is simply a no go. And again we end up needing the Clean All (not Clean) command. That is, ofc, only needed in cases where you either don't know what was on the drive or you are in doubt about infections etc.
Of course if you want to be completely sure no data can be recovered, melt the old hard drive and use a new one.
I've been gone from this discussion a few days.
I'll have to skip the Ubuntu. I'm not familiar with that, and I would be back here asking 10 questions again. And she doesn't want any data from the computer, not even the photos and docs she left on. I tried burning the DBan ISO onto a disk, and it refuses to be copied.
This discussion has gotten so long and complex. I want to clarify: It's best to attach it to this computer and use DiskPart CleanAll? There's no chance of wiping the wrong one because the 2 partitions in this machines are named SYSPROGC and DATAD
Rochelle
Ofc you can use 'diskpart / clean all' on the disk that you are wiping. You just gotta do it right before the installation of Windows, and launch command prompt there. A real guru explains how to do that here - DISKPART : At PC Startup - Windows 7 Help Forums and SSD / HDD : Optimize for Windows Reinstallation - Windows 7 Help Forums I'm surprised the support staff hasn't pointed you to these threads by now.
Why would you attach the hard disk to another computer? Keep it in the computer where it is and perform the clean all there, with CMD, right upon the language selection screen of installing windows. Unless I misunderstood you, then no need for extra trouble...
I didn't know I could run Diskpart from the installation disk. I've never had to wipe a disk so thoroughly before, only my own disks.
The support staff has been helping me. You went to my original problem and skipped all the replies, then read my most recent question.
Yep well you can even use other cleaners too see this list and as some are very nuclear you need to use with caution but they are thorough Best Free Hard Drive Eraser | Gizmo's Freeware
