Check Disk - Reset
Page 1 of 5 123 ... LastLast
    Check Disk - Reset
    Check Disk - Reset
    How to Reset Check Disk to Not Run at Startup
    This will show you how to reset Check Disk or chkdsk back to it's default state of not running at the next startup. This can be handy if you had scheduled disk check to run on the next startup and changed your mind, or Check Disk will not stop running at startup.
    See also: The Chkdsk.exe program does not start correctly on a Windows 7-based computer
       Warning
    You must be logged in as an administrator to be able to do the steps in this tutorial.
    OPTION ONE
    Reset chkdsk using an Elevated Command Prompt
    1. Open an elevated command prompt.
    2. To Check to See if a Disk Check is Scheduled for a Drive
    A) In the elevated command prompt, type the command below and press Enter. (see screenshots below)
    NOTE: Substitute C: in the command below with the drive letter of the drive you wanted to check instead.
    chkntfs c:
    If scheduled to run chkdsk at next startup, you will see this:
    If not scheduled, you will see this:
    3. To Cancel a Scheduled Disk Check for a Drive
    A) In the elevated command prompt, type the command below and press Enter. (see screenshot below)
    NOTE: Substitute C: in the command below with the drive letter of the drive you wanted to cancel the scheduled disk check to run at the next startup for instead.
    chkntfs /x c:
    4. When finished, close the elevated command prompt.
    OPTION TWO
    Reset chkdsk using a REG File Download
    1. Click on the download button below to download the file below.
    Reset_Chkdsk.reg
    2. Save the REG file to your desktop.
    3. Right click on the downloaded REG file and click on Merge.
    4. When prompted, click on Run, Yes, Yes, and OK to approve the merge.
    5. You can now delete the downloaded REG file if you would like to.
    OPTION THREE
    Reset chkdsk using Registry Editor
    1. Open the Start Menu, then type regedit in the search box and press enter.
    2. If prompted by UAC, then click on Yes or enter the administrator's password.
    3. In regedit, navigate to the location below. (see screenshots below)
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager
    4. In the right pane, right click on BootExecute and click on Modify. (see screenshots above)
    5. Copy and paste either command below, and click on OK. (See screenshot below)
    (Default do not run)
    autocheck autochk *
    OR
    (Disable chkdsk for C: drive)
    autocheck autochk /k:C *
    6. The registry will now look like this. (see screenshot below)
    7. Close regedit.
  1. Posts : 416
    windows Ultimate
    I have HKEY LOCAL MACHINE, but the rest I don't have.
  2. Posts : 8,476
    Windows® 8 Pro (64-bit)
    Hi Rose, that isn't possible. Look again. I can see This registry path even on a Windows XP computer.
    BTW, this tutorial works with XP as well.
  3. Posts : 72,052
    Hello Rose,
    You can use OPTION ONE to use the download to have this (OPTION TWO) done automatically for you. :)
  4. Posts : 49
    Windows 7 Ultimate 32bit
    Thanks a lot for another great tutorial.
  5. Posts : 243
    Windows 7 Professional 64 bit SP 1
    Thanks Brink, I have downloaded the reg file and use it, I don't know if next time I restart my computer will there be any auto checking on my E: drive or not, because it stuck at "Windows Is Starting" for about 5-10 minutes and only start disk check itself! But when I'm log on to Windows and I click on "My Computer", the E: drive is not accessable!
  6. Posts : 72,052
    Hello Mual,
    There may be an issue with your E: drive. Depending on what brand the HDD is, you might run correct program below to scan the HDD with to see if it may be failing or dead.
    Seagate (SeaTools) SeaTools | Seagate
    NOTE: Click on "Downloads" there.
    OR
    Western Digital (Data Lifeguard Dagnostic): WD Support / Downloads / SATA & SAS / WD Green / GP
  7. Posts : 243
    Hello Brink, if it is dead, or either is failling, there is no way to save the hard disk already?
    I'll download and dignose soon :)
  8. Posts : 72,052
    If it's dead, then no. However, let's see what the results say. Fingers crossed.
  9. Posts : 243
    Sorry, is late right now, I'm gonna take a rest, tomorrow I'll give a feedback, thanks for providing the link
    I check on all the Seagate drive already, and it pass SMART test, but which fix or scan should I apply to fix the bad sector? From the basic tests tab, there are a few option there. I used the SMART test, other I not sure. Can you guide me?
    And what does it mean the SeaTools will fail the drive if not success repairing the bad sector? Means the tools might damage the hard disk?
