Display Color Calibration
Page 5 of 8 FirstFirst ... 34567 ... LastLast
  1. Posts : 72,058
       #40
    Veganula said:
    Hi Brink,
    thanks for your time. Yes, I can adjust the monitor settings but it's not enough. Somehow the Dell computers have this wired greenish shade, visible especially on gray, and the yellow is much lighter than on other computers. I am making a small website and it is important that what I think is yellow, is not a dirty creamy color. I tried 2 other computers before this one, and they all had the same problem.
    I read on another forum that it's a problem on earlier Win 7 version, but I updated my Windows and nothing changed.
    I would have to upgrade it but it seems to be a very dramatic solution.
    Thank you again.
    You're welcome. If I can find anything else on this, I'll be sure to post back.
  2. Posts : 4
    Windows 7 premium x64
       #41
    THANKS!
  3. Posts : 2,393
    Microsoft Windows 7 Ultimate: x64 (SP1)
       #42
    Seemed to help quite a bit regarding my laptop!
    Thanks Brink!
    Best Regards,
    FredeGail
  4. Posts : 72,058
       #43
    Cheers FredeGail. :)
  5. Posts : 4
    Windows 7 Professional 32-bit SP1
       #44
    I think I've solved the problem of losing color calibration through Intel driver. I read somewhere to disable "igfxpers.exe", which is Intel's persistence module (nice name, isn't it?) and graphic driver stop re-loading after resume. I disabled this module via msconfig. Now LUT sticks!
  6. Posts : 72,058
       #45
    Hello Tempoct,
    Thank you for posting back with your results. I have added this in the Warning box at the top of the tutorial to help others with this. :)
  7. Posts : 476
    windows 7 ultimate 64bit
       #46
    Hi
    thanks for the great tutorial
    i have a profile created with a colomunki and one created with spyder , i rent them
    now i have uninstalled their software
    how can i load a monitor default profile (i mean not calibrated)?
    i mean how can i load "not calibrated" or upload "a loaded profile"
    , in short have a not calibrated monitor?
    thanks
    cheers
  8. Posts : 72,058
       #47
    Hello Drugo,
    You could Remove all profiles and uncheck the Use my settings for this device box for each monitor. :)
  9. Posts : 476
       #48
    Brink said:
    Hello Drugo,
    thanks SIR
    and do i need a reboot ?
    i tried with a monitor calibrated profile!
  10. Posts : 72,058
       #49
    You're most welcome Drugo. No need to reboot to apply. :)
