Sticky Notes - Create and Delete
  1. Posts : 72,061
    Hello 3timesoccermom, and welcome to Seven Forums. :)
    If you have any sticky notes opened, you will need to log off and log on to apply after changing the DWORD below to 1.
    Sticky Notes Delete Confirmation - Enable or Disable in Windows 7 8 - Windows 7 Help Forums
  2. Posts : 8
    Windows 7 Pro
    OK thank you. I will try that.
  3. Posts : 72,061
       #12
    You're most welcome. Please let us know how it went. :)
  4. Posts : 8
    Windows 7 Pro
    Brink thank you for taking the time to reply but I changed it to 1, then re-booted my computer and it did not work. I created a new sticky note and hit the "x" and it was deleted with no warning.
  5. Posts : 72,061
       #14
    Does the PROMPT_ON_DELETE DWORD still show being set to 1?
    Just to verify, are you running the stikynot file for Sticky Notes? I only ask in case you may have installed and using a 3rd party Sticky Notes type program instead.
  6. Posts : 8
    Windows 7 Pro
       #15
    I'm running the one that came on the computer. I am not very savvy about these things so not sure how to tell that.
  7. Posts : 8
    Windows 7 Pro
       #16
    Does this help?
    Attached Thumbnails Attached Thumbnails Sticky Notes - Create and Delete-5-2-17-sticky-notes.jpg
  8. Posts : 8
    Windows 7 Pro
       #17
    I just noticed the value for the "prompt on..." is now back on 0. Not sure why.
  9. Posts : 72,061
       #18
    As a test, change it back to 1, but only log out and log in instead of restarting the PC to see if it will stay set to 1.
  10. Posts : 8
    Windows 7 Pro
       #19
    testing
