CTRL+ALT+DEL Screen - Add or Remove Task Manager
    How to Add or Remove Task Manager from the CTRL+ALT+DEL Screen
    This will show you how to add or remove the Start Task Manager option in the Windows 7 CTRL+ALT+DELETE screen for all users on the computer.
    EXAMPLE: CTRL+ALT+DEL screen
    NOTE: This is when you press CTRL+ALT+DEL with Start Task Manager added by default (left screenshot below), and removed (right screenshot below).
    OPTION ONE
    Using a REG File Download
    1. To Add Task Manager to CTRL+ALT+DEL Screen
    Add_Task_Manager_CTRL+ALT+DEL.reg
    B) Go to step 3.
    2. To Remove Task Manager from CTRL+ALT+DEL Screen
    Remove_Task_Manager_CTRL+ALT+DEL.reg
    3. Click on Save, and save the .reg file to the desktop.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, System, and Ctrl+Alt+Del. (See screenshot below)
    CTRL+ALT+DEL Screen - Add or Remove Task Manager-task_mananger_group_policy.jpg
    3. In the right pane, right click on Remove Task Manager and click on Edit. (See screenshot above)
    4. To Add Task Manager to CTRL+ALT+DEL Screen
    A) Select (dot) either Not Configured or Disabled. (See screenshot below step 6)
    B) Go to step 6.
    5. To Remove Task Manager from CTRL+ALT+DEL Screen
    A) Select (dot) Enabled. (See screenshot below step 6)
    6. Click on OK. (See screenshot below)
  1. Posts : 14
    Windows 7 Ultimate x84 (32 Bit)
    I don't have "User Configuration" in my "Local Group Policy Editor" can you help me? And is there any way to enable this just for admins?
  2. Posts : 72,052
    Hello Danny,
    You should. Double check to see if you may have just missed it. If you don't, then please post a screenshot of your gpedit.msc window.
    In the mean time, you can do OPTION ONE instead to do the same thing. :)
  3. Posts : 14
    Sorry I was looking in the Local Security Policy Editor lol
  4. Posts : 72,052
    LOL, no problem. Don't you love it when that happens.
  5. Posts : 4
    Can this done frome visual basic please ?
  6. Posts : 72,052
    Hello ybydb, and welcome to Seven Forums.
    Yes, you should be able to add and set the same registry values in the .reg files in this tutorial with Visual Basic.
    How to: Create a Registry Key and Set Its Value in Visual Basic
    How to: Set Values in Registry Keys in Visual Basic
    Hope this helps, :)
  7. Posts : 4
    Hi Shawn
    Thanks for the quick reply. Is this also valid for local group policy please ?
    Regards, Yvan
    I meant: the code you are referring to is reading registy values but doesn't seem to work with local group policy...
  8. Posts : 72,052
    Yes. You would just need to look up the registry key and values for the group policy to do so. :)
    Group Policy Search
