#40
Try that
Icon Cache - Rebuild
Try that
Hello Mojonba, and welcome to Seven Forums.
If rebuilding the icon cache suggested by Yowan above doesn't help, then.......
Double check to see if you have the registry location below, and that it is empty as well.
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\DriveIcons
Also, check using OPTION ONE to see if you may have a autorun.inf file in the root directory of these HDDs as well.
thanks for the replies guys,
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\DriveIcons doesnot exist.
Rebuilding icon cache didnot work. And there is not autorun.inf in any drive.
Mojonba,
When you were looking for a autorun.inf file, did you also check the Show hidden files, folders, and drivesoption in Folder Options in case the autorun.inf file may have been hidden?
Mojonba,
Since that looks good, lets try downloading and merging the drive option in the tutorial below and restarting the computer afterwards. This will restore the default associations for drives which also includes the default icon. If something else it not changing your icon, then hopefully this may restore the default icon.
Brink
I downloaded and ran Default_Drive.reg, restarted and nothing. Still no default icons. Unless you have other ideas to restore the default icon, I believe my only option is to setup a custom icon with the default icon.
Thanks.
Mojonba,
LOL, that was going to be my next suggestion to do OPTION ONE or OPTION THREE in the tutorial for a custom icon using the default icons in the imageress.dll file. :)
