Drive Icon - Change
Page 10 of 12 FirstFirst ... 89101112 LastLast
  1. Posts : 72,061
       #90
    Hello Kaldarien, and welcome to Seven Forums.
    Looks like you will need to do OPTION ONE or OPTION THREE instead to make the icons stick.
    Hope this helps. :)
  2. Posts : 8
    Windows 7 Ultimate x32
       #91
    Help me fix this error
  3. Posts : 72,061
       #92
    Hello ngoctraiden, and welcome to Seven Forums.
    You might first see if rebuilding the icon cache may help.
    If not, then you could use OPTION THREE in the tutorial on the first page to change the icon to be this below at step 10 that should restore it.
    C:\Windows\System32\imageres.dll,-36
    Hope this helps, :)
  4. Posts : 8
       #93
    i want to use this Icon for my disk C
    HDD RhorDisk.rar
    I use IconPakage to fix error, but it's not working
  5. Posts : 72,061
       #94
    ngoctraiden,
    That's a .png file. You will need to use an .ico file instead. I created one for you from the PNG file, and uploaded it in a ZIP file below for you.
    You would just need to extract (drag and drop) the .ico file from the ZIP, unblock the .ico, move the .ico to where you like to keep it, then just use the path to this .ico file instead. :)
    Drive Icon - Change Attached Files
  6. Posts : 8
       #95
    Brink said:
    ngoctraiden,
    Thank u so much
    My problem is solved
  7. Posts : 72,061
       #96
    You're most welcome. :)
  8. Posts : 27
    Hi Shawn,
    just changed my drive icons using "autorun.inf" files. Nice to get rid of
    six boring grey generic drive icons plus one for the system drive,
    the "Windows Orb" is much more impressive than the one Windows used.
    And "Surprise, Surprise", the icons in the navigation pane changed also !!
    I didn't expected that, thinking about it, it's logical, but it's Windows ...
    Reading the posts here, it seems that Forum Rule No. 1 is
    "Whatever can go wrong will go wrong." (aka Murphy's Law)
    Thanks for this tutorial,
    Tom
  9. Posts : 72,061
       #98
  10. Posts : 27
    Addition
    Seems that Option One with the "autorun.inf" doesn't work, if the drive
    is a "True Crypt" volume (a completely encrypted partition).
    So I tried Option Three instead.
    Shawn: "13. The changes should be immediate ..."
    Windows and no reboot ??
    Oh YEAH, Shawn, you're right, sweet !
    Regards,
    Tom
