Gadgets Shortcut - Create
    How to Create a "Gadgets" Shortcut in Windows 7
    This will show you how to create or download a Gadgets shortcut that opens to the same location when you right click on the Desktop and click on Gadgets.
    EXAMPLE: Gadgets
    OPTION ONE
    To Download a "Gadgets" Shortcut
    1. Click on the download button below to download the Gadgets.zip file.
    2. Click on Save, and save the .zip file to the desktop.
    3. Open the .zip file and extract the Gadgets shortcut to the desktop.
    4. Right click on the Gadgets shortcut, and click on Properties, General tab, and on the Unblock button. (See screenshot below)
    5. You can now Pin to Taskbar or Pin to Start Menu this shortcut, assign a keyboard shortcut to it, or move it where you like for easy use.
    6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
    OPTION TWO
    To Manually Create a "Gadgets" Shortcut
    1. Right click on a empty area on desktop, and click on New and Shortcut.
    2. Copy and paste the location below into the location area, and click on the Next button. (See screenshot below)
    %windir%\explorer.exe shell:::{37efd44d-ef8d-41b1-940d-96973a50e9e0}
    3. Type Gadgets for the name, and click on the Finish button. (See screenshot below)
    4. Right click on the new Gadgets shortcut on the Desktop and click on Properties.
    5. Click on the Shortcut tab, then click on the Change Icon button. (See screenshot below)
    6. In the line under "Look for icons in this file", copy and paste the location below and press Enter. (See screenshot below)
    %ProgramFiles%\Windows Sidebar\Sidebar.exe
    7. Select the icon highlighted in blue above and click on OK. (See screenshot above)
    NOTE: You can use any icon that you would like instead though.
    8. Click on OK. (See screenshot below)
    9. You can now Pin to Taskbar or Pin to Start Menu this shortcut, assign a keyboard shortcut to it, or move it where you like for easy use.
  1. ryo
    windows 7
    nice tutorial...
  2. Posts : 72,062
    Thank you RYO. I'm happy that you like it. :)
