How to Create a Keyboard Properties Shortcut in Windows 7
This will show you how to create or download a
Keyboard Properties shortcut. You can also
Pin to Taskbar or
Pin to Start Menu this shortcut, or move where you like in Windows 7 for easy use.
EXAMPLE: Keyboard Properties
OPTION ONE
To Download the "Keyboard Properties" Shortcut
1. Click on the download button below to download the file below.
Keyboard_Properties.zip
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract the Keyboard Properties shortcut to the desktop
4. Right click on the
Keyboard Properties shortcut, and click on
Properties,
General tab, and on the
Unblock button. (See screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create the "Keyboard Properties" Shortcut
1. Right click on a empty area on desktop, and click on
New and
Shortcut.
2. Copy and paste the location below into the location area, and click on the
Next button. (See screenshot below)
C:\Windows\explorer.exe shell:::{725BE8F7-668E-4C7B-8F90-46BDB0936430}
OR
RunDll32.exe shell32.dll,Control_RunDLL main.cpl @1 3. Type
Keyboard Properties for the name, and click on the
Finish button. (See screenshot below)
4. Right click on the new
Keyboard Properties shortcut on the Desktop and click on
Properties.
5. Click on the
Shortcut tab, then click on the
Change Icon button. (See screenshot below)
6. In the line under "Look for icons in this file", copy and paste the location below and press
Enter. (See screenshot below)
%SystemRoot%\System32\imageres.dll
7. Select the icon highlighted in blue above and click on
OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on
OK. (See screenshot below)
9. Move the shortcut to where you like for easy use.
