Startup Repair
Page 8 of 18 FirstFirst ... 678910 ... LastLast
  1. Posts : 3
    my problem solve...
    tq very much...really helpfull...
  2. Posts : 72,058
       #71
    You're most welcome Goldhanter, and welcome to Seven Forums. :)
  3. Posts : 37
    windows 7 ultimate x64
       #72
    same problem
    Dear guys, Iīm new here. I had the same problem last night. PC got frozen, I restarted with the button, and appeared in the window with the options to either go to startup repair or to start windows normally. Either one I chose it gets to the same screen.
    I tried the STARTUP REPAIR first,
    the first time, it didnīt find any operating system, anyway it ran, but said the problems couldnībe fixed. So I restarted
    second time, found the operating system, ran startup repair, checked for half an hour and appeared a sign saying "repairing disk errors, this might take over an hour to complete" and kept like that for eight hours, until I read in this thread that it shouldnīt take so long, so I restarted.
    third time, found operating system, running now again startup repair, half an hour to get to the sign about the disk again, now Iīm planning to wait no more than 1 hour to make the next step.
    What I would like to know your advice about is
    1. should I try how many times to do START UP REPAIR?
    2. in case I should take a different solution, which is first, system recovery or repair install?
    thanks for your advice, I use the pc to work and need to solve this asap.
    thanks again
  4. Posts : 3,427
    Hi casiopea,
    Sometimes, depending on how bad it is, you may need to run Startup Repair up to 3 times, it should never take more than that though.
    In case I should take a different solution, which is first, system recovery or repair install?
    Unfortunately, a repair install (I believe) can only be done from within a booting copy of Windows, In which case your only option would be a Custom Install, or recover a system image. Brink or someone else may have a better solution for you, but I'm fairly certain that if Startup Repair is failing, there is probably something seriously wrong with your installation.
  5. Posts : 72,058
       #74
    Hello Casiopea, and welcome to Seven Forums.
    Did you make any changes or install anything before this happened?
    You might see if doing a system restore at boot (if able) using a restore point dated before you had this issue may help.
    If not, then Martin's post above is a good suggestion. If running startup repair up to 3 times cannot fix it, then it may be best to do a custom install if you have files you need to save, or a clean install if you do not.
  6. Posts : 37
       #75
    thanks Brink, as many others here, Iīve done nothing special before the brakedown
    I tried to do a SYSTEM RESTORE using the same cd I used for STARTUP REPAIR, but when I click on SYSTEM RESTORE, it stays there, thinks for a second, but donīt go anywhere.-edit- sorry, it just took a long time until a window appeared, saying THERE IS NO POINT CREATED TO RETURN TO. so, I will try one more time to do STARTUP REPAIR, and then...
    I think I will try CUSTOM INSTALL then, so that I save some files I preffer to keep. the problem I see is that I will loose programs and drivers installed, thatīs not nice
    thanks a lot guys
  7. Posts : 72,058
       #76
    You're most welcome Casiopea. Please let us know how it went. :)
  8. Posts : 16,163
    7 X64
       #77
    It's probably registry corruption.
      My Computers
  9. Posts : 37
       #78
    Thanks SIW2, sorry but I īm not an expert. In case it is how you say, which would be the better solution? many thanks
  10. Posts : 16,163
    7 X64
       #79
    This my own method for doing it - don't go making tutorials out of it please.
    Boot your 7 recovery cd. Go to command prompt.
    Type :
    notepad
    (then press enter )
    when notepad pops up, click File >Save
    Navigate to Windows\system32\config\regback
    (It's a pain , but you will need to keep selecting "All Files" in notepad dropdown. )
    Rt click and copy SOFTWARE (file with no extension )
    then navigate to Windows\system32\config rt click and paste - overwrite the existing SOFTWARE .
    Now go back to Windows\system32\config\regback , copy SYSTEM
    then navigate to Windows\system32\config rt click and paste - overwrite the existing SYSTEM
    repeat for DEFAULT, SAM and SECURITY .
    Then try startup repair and reboot.
    Can you follow that ?
      My Computers
Đ Designer Media Ltd
