Startup Repair
Page 11 of 18 FirstFirst ... 910111213 ... LastLast
  1. Posts : 37
    windows 7 ultimate x64
       #100
    SIW2 said:
    yes.
    If startup repair doesn't work , scroll down thru the list it gives all the way and see what it tells you.
    Thanks, it is running now, it scanned for about 13 minutes and then appeared the sign saying
    "repairing disk errors, it might take over an hour"
    My question was because the other tries I did, the process took way over an hour (8 to be exact) and kept doing the same, processing, so the only thing I can do is restart the computer, so then, I dont get any listing as result.
    IŽll wait and hope this time the startup repair works normally, but if it keeps rolling and rolling endless, I guess I will have to shut down, and go for the custom or clean install,
    thatŽs why I was asking if the choice in that case would be that disk
    many thanks
  2. Posts : 72,058
       #101
    Hopefully the other bad installation disk was all that was wrong, and it will work this time for you.
  3. Posts : 37
       #102
    Hi guys, nothing worked, IŽll follow this on the Clean Install thread, as the story goes in that direction
  4. Posts : 72,058
       #103
    I hope that will go smoother for you.
  5. Posts : 1
    7
       #104
    i really need your help
    My problem is, the start up repair option doesn't start. I have no win 7 disk and no matter what I do, I can't get the screen to go beyond compressed bootmgr. Believe me I have tried everything known to man other than taking it into the geek squad. I cannot get in......I have an HP touchsmart system
  6. Posts : 72,058
       #105
    Hello Chephren, and welcome to Seven Forums.
    If you have a friend that you can borrow a Windows 7 installation disk from, or create a system repair disc on another computer to use on yours, you could try the tutorial below to fix the compressed bootmgr with it.
    BootMGR Compressed Message at Boot Fix - Vista Forums
  7. Posts : 1
    Windows Server 2008 R2 Standard
       #106
    If I do a start up repair will it replace the startup with old files.
    What I mean is my disc is Windows 7 with no SP and my computer is SP1.
    So all the updated files start up files will be replaced with old files?
  8. Posts : 72,058
       #107
    Hello BlueBird, and welcome to Seven Forums.
    No. A startup repair only attempts to fix the partition code, bootmgr, bcdBCD, MBR (Master Boot Record) if needed. This is what affects the bootloader to be able to boot Windows. This is not for the startup programs.
  9. Posts : 2
    Windows 7 64bit
       #108
    Hey.
    First, sorry for my poor english.
    Two weeks ago, my laptop couldnt start Windows 7 normally, so I created a Win 7 Repair Disk, used the "startup repair" option and it worked great. I could use my computer normally.
    Yesterday, again I had problems starting Windows 7 (didnt start) and used the Repair Disk thinking that it will help me out again. This time I had no luck.
    My startup repair is running (8 hours and counting) and still I have the blue block coming and going with the "trying to fix problems" below.
    Should I turn it off? Meaning, is it a given that it wont solve any problem since it has been 8 hours since I started the startup repair?
    Thanks!
  10. Posts : 16,163
    7 X64
       #109
    It is not working if it has been running that long.
    Try system restore to a point before you had the problem.
      My Computers
